Borgeson PS Steering Pump flex...
Background: I added the Burgeon PS unit to my 67 small block a while ago and was hopeful to improve the feel of the steering. (All other parts of the suspension and steering components/bushings were replaced just before this install). The alignment has been done by a knowledgable corvette shop and still the whole event was a disappointment, because my steering still felt "mushy" and not much different than what I had with a stock PS system.
Issue: However, a few weeks ago I was under the hood doing some tuning and the person helping me happened to rotate the steering wheel and I saw the entire Burgeon steering pump assembly twist/flex side to side...as if the pressure on the system while sitting still was causing the unit to twist. I don't recall the old/original ever twisting or exhibiting ANY signs of movement.
Questions:
1. In seeing this Burgeon unit flex/twist, it seems to me that this is NOT supposed to happen? But I don't know for sure.
2. It also seems to me that the flex/twist I am seeing is contributing to the "mushy" steering I am feeling?
3. I retorqued the mounting bolts and they are tight...maybe I should add some larger flat washers to the mounting bolts to help distribute the load in hopes the flex/twist will stop?
Curious what others think?
Cheers,
Frank
Questions:
Cheers,
Frank
Are you talking about the pump or the steering box? My steering box "twists" on hard right or left only. It would seem stiffening would help, not washers, but 1 solid load spreading plate instead.
The "mushy" feel could come from caster specs. Borgeson power steering likes a lot of caster and that really is one of the benefits of using it. The stock a-arms are not capable of bringing the caster into Borgeson recommended specs. This most likely has nothing to do with your problem.
If you had "mushy" steering before then I would suspect a problem elsewhere because you changed the steering box and the problem persists. I also don't think it has anything to do with any "twist" you noticed for the same reason.
Questions:
Cheers,
Frank
Questions:
Cheers,
Frank
I've seen few conversions on the C3 section where they cut out the frame where you bolt on the steering unit to the frame and welded a thicker reinforced piece to take the load. I'm watching this place to see if others have come across the same issue.
