S 10 Rim for spare wheel tub in c2
Somewhere I read these would fit as an emergency spare, not only the 5 lug pattern but also inside the spare tire tub. Can't find the thread in the search, so gotta ask. For my 64. Can get a 94 S10 wheel pretty reasonable. Thanks.
Ron
Ron
Cruise-In III Veteran
Sibes67,
Here ya' go.
https://www.corvetteforum.com/forums...wheel-tub.html
and, here's a link showing it in my tub.
https://www.corvetteforum.com/forums...e-carrier.html
:thumbs;
Jim
In God We Trust!
Here ya' go.
:thumbs;
Jim
In God We Trust!
Location: About 1100 miles from where I call home. Blue lives matter.
Received 5,321 Likes
I found one in a parts place for $30; Ive seen them on ebay for $75ish.
Mine looks just like the one pictured above. Just remember, if you have posi (and I do) then if the diameter of the S-10 spare is different than your regular tire you can't use it on the back (not for long anyway). You'll have to do a double tire change and move a full size tire to back and put the spare on the front; otherwise you can wear out the clutch pack.
I used one for awhile (from a 1998 S-10) and then I took a look at the rubber on the tire. That thing is so badly cracked, I'm glad that I never needed to use it. Same goes for the spare that is currently under my 1998 S-10.
Ray
Ray
Mine has never been on the ground and was stored in climate-controlled storage its entire life. I don't ever intend on using it....Green Slime and AAA come first...S-10 spare is for the zombie apocalypse.
Ron
What you want is an S-10 compact T155/90D 16 spare with a 4-3/4” bolt pattern.
When the car was crash tested, the guys running the test removed the spare tire which negatively affected the already dismal impact results.
I read this book which gives a great account of the worst car ever made:
Just thought I'd share.
After reading the book and learning so much about the Yugo I had to find one. I eventually did and took some pics. Here's one under the hood. IIRC, the guy selling wanted $6K for the car.
