How to Change over to LED lighting?
I,m thinking of changing tail lights over to LED's. What all has to be done to make this change? I have a 64 coupe.
I do that on all my classic cars. You can get the LED tail lights from Bruce (ohiovette) on the forum here along with an electronic signal flasher. Installation is all of 20 minutes if you buy the complete weather-proofed tail light lens with integrated circuit board and not the separate LED bulb.
On a '63 I kept hitting the larger, electronic flasher with my left foot and dis-lodging it...so I made up some short wire 'extensions' with spade connectors to go into the fuse box and allow me to move the flasher up out of the way where I could zip-tie it to a dash support
LEDs are a no brainer and much more visible to those tail-gating jerks jabbering on their cell phones.
Received 1,581 Likes
St. Jude Donor '20-'21-'22-'23-'24
-- Steve
Will the 1157 replacement LED bulbs fit in our GM bulb sockets and clear? I know that Walmart sells a set of red Pilot LED bulbs for 1157 replacements for about $15 which is pretty inexpensive. I tried them on my Cobra replica and they are very bright as tail lights although the brake and flasher circuit are not as bright as Superbrightled bulbs.
Bruce (ohiovette) is a great guy too! He answered my questions about LED's for 67 back-up lights and also sent me bulbs for the front parking lights. He didn't think they would be an improvement over incandescent bulbs and was correct.
Rick
Rick
Those PILOT LED lights got some pretty bad reviews on amazon. I'll be interested if you can update this thread in a month and let us know if they are still working.
I like Bruce's products for my C1.
Fellow forum member Radioflyer has great LEDs for the later "plug in" socket bulbs (I have them on the C5), but the flasher must also be changed (or load resistors added).
Plasticman
Plasticman
From my own experiences in trying to get the Superbrightleds to function in my ERA (it would take a lot of time to recap) and from various stories I've seen on numerous forums with LED 1157 replacements in general, proper operation is sometimes a hit or miss experience.
The low point of experiences on my ERA was when I tried one of the Pilots in my front turn signal just because it has a screw off lense and I wanted a quick test - plugged it in and turned on the turn signal and all four lights flashed in unison (and it doesn't have emergency flashers). Installed them in the rear and they functioned perfectly.
I got a set of the red tail light LED assemblies (lens/LED unit) from Zips, part # L-560 which list for $28.95 each. 5 minute plug and play. Installed about 2 years ago and no issues. MUCH brighter than incandescent and look stock until of course they light up.
IIRC correctly, I didn't have to do that on my '63 for some reason.
Dang - wish I had know that..I spent 1/2 day with two different flashers trying to figure out the deal and had to get an internal circuit diagram of the flasher to come up with my Rube Goldberg rig
So, I now have an adapter on the way
FYI - the old mechanical flashers require resistors somewhere in the lighting circuit to generate the load to activate them. Sometimes, if you just change the rear lights to LEDs; the front bulb filaments still have enough "load" to make the old flasher work; sometimes not.
If you go full LEDs on all four corners your old flasher will almost certainly not work. In the early days of LEDs they came out with load resistors to wire in the lighting harness to provide the "load" to activate the old flashers. These things got hot, consumed electricity equivalent to the old bulbs and were dangerous if installed wrong.
Fortunately, electronic flashers eliminate all that BS and don't require the "load" that the old flashers did.
So far the stock, old, flashers have worked OK in the 3 cars I put LEDs in the tail lights only. I have not installed LEDs up front on any of them.
I was particularly surprised everything worked in my 67 GTX with all original wiring harness. Most of these things have had a dash fire or half the electrical stuff usually doesn't work on them by now.
