I'm about to make major changes to my C2
As for the negativity on the forum...it happens quite frequently...and its unfortunate...most of the negative comments wouldn't occur if these discussions were in person, nothing like hiding behind a monitor, therefore, I mostly try ignore them.
As for your exhaust conundrum...there are folks here who have added electric exhaust cutouts which allow both the undercar exhaust and sidepipes to be used either simultaneously OR just the undercar exhaust system to be used. It looks pretty slick. This could help your decision process.
I am interested to follow your progress...I have the same feedback for the VBP suspension systems. As for going the new chassis route, I like this idea but I am not willing to commit the time or resources to make it happen. The C2 Ridetech piece is interesting and I will eagerly follow along...given my disappointment with the VBP setup I have, I will not throw any more money at my suspension until I have first-hand ridden/drive in a car that has the Ridetech mod. Are you going level 2?
If I never get the chance to ride/drive one then it wont ever happen and I am fine with that. I do know the VS sytems have been used/discussed and they reviews have been mixed...your comments that suggest the VS is "lacking in ride quality", totally match the feedback I have seen. I don't think the VS option is the answer.
Good luck!
Frank
Good luck!
Frank
Frank
My plan is to go level 2. No need for L3 for a street car. One thing I've been told us that their mono-tube shock design is far superior to the QA1's used on the VS setup. Once I get this all done, and if it's as good as I'm hoping, I'll probably consider swapping out the shocks on my C3 and see what difference it makes. With that said, on my C3 I only have the VS coil overs on the front. The back has a mono spring and QA1's. The ride quality starts back there and I know I don't have the best setup. Maybe, again only if it's the real deal, I'll consider putting the RT rear coil over setup in the C3.
I'll get some pics of the flares and post them soon.
I applaud all who take the time to document on this forum what they are doing on their car. It does not matter if it is my style/taste/preference/mod or not. The information provided is always of value to someone out there, as it has been a zillion times to me
If you trans does not have the plug below or plug it has does not have the 2 pins circled in RED, you will have to replace trans if not or see if it can be modified with components and plug that spports LS3/7/LT1 engine ECM requirements.
Suggest you research this.
100% Looking forward to the build!!
I'm on board with you!
I'd recommend keeping the undercar exhaust, as you have many more options for producing power with great sounding exhaust note. You can always add electric dump valves to run open headers if you want to. Sidepipes are great, and I love mine, but you MUST MUST MUST fabricate custom exhaust system that will fit within the original covers. Looks like you will be making 500 plus HP in Phase II. If you don't mind the noise, then I suggest you build your exhaust system around these:
http://www.classicchambered.com/classic/products.html
scroll down to 2540 VP
On my 470 HP 327, these mufflers resulted in a mere 6 RWHP power loss versus open headers!
The sound is mellow while cruising, but they bark like hell when you mash the throttle. Your coupe will reflect and attenuate the sound, you know.
LS engines and sidepipes.
I never heard a stock or modified LS3/7 engine sound good with Side pipes. Unlike old style engines they sound like you have a 4 Cylinder engine in car. You hear each of the exhaust pluses of 4 cylinders that exit on side of the car you are standing on. To me you don't get the rumble sound of orginal engines make when standing at side of car, so many here seem to like or think they would...
If I had side pipes on the LS3 430HP or 480HP engine they would make you puke when standing at side of car. Same can be said of LS7 going in 3rd car. Thats just one of the reasons I have under car rear exit exhaust on both, soon to be 3 LS powered cars. Power lost is bad enough with my homemade headers and True 3.0" exhaust from collectors to muffler exit, so I don't need Sidepipes to make it worst...
Looks or Power
Looks or Power
observations:
1)make it what YOU want, you only go around once! I support you.
2) I seriously dislike the look of side exhaust, I'm not alone but I realize I AM in a serious minority, and it's all preference
3) If I were doing the build, I'd hold off body and paint as long as possible, do as much as you can before you make it shiny again. There will be a lot serious surgery going on right around you slick new paint.
#34
Very interested in this project. Are you selling the VS stuff? I'd be more than interested...
Subscribed.
Subscribed.
#35
Frank
#36
Jay, the VS stuff is on the C3. It's staying on. The C2 has VBP front and back. I'd be HAPPY to sell you that stuff.
65TB, two main drivers are concerns about exhaust smell and the fact that I've got too much money tied up in the exhaust already. The comments here helped push me over the edge. If I keep it focused on body, suspension, and steering, I'll stay in budget.
Maybe?!?!?!?
Maybe?!?!?!?
#37
Budget.... good.
You know how it works ...
Make your plans. Add up all the numbers. Be generous and add a bit.
Then Double it.
Works for me.
Every time.
Uncannily accurate.
Then Double it.
Works for me.
Every time.
Uncannily accurate.
#38
The exhaust problem is so simple. Side exhaust is so loud , HP loss. Under car exhaust more HP and cabin quieter. Install those electric exhaust cut outs and have both.
#39
Poorhousenext........thanks for the 4L60 info. I had no clue about what you told me. That clearly will impact what happens down the road. I don't think it has what it needs. Gearstar built this tranny for me, for this engine, 8 years ago. I doubt they modified it for electronic controlled options, but you never know until you check it out.
#40
C2 of Year Finalist (performance mods) 2019
I love side pipes, but if you want you can fake them. Just get the covers and a chrome tip. It will look like it has side pipes, but will use your existing exhaust system. Headers will be easier too.
