64 dash bulbs (how many)
getting ready to install the dash on my 64 with air, how many LED BA9s bulbs will it require? (including the radio and pull *****) Thanks !
Received 1,857 Likes
Received 6,943 Likes
2015 C2 of Year Finalist
Why do you need LED. If the cluster was properly restored OEM bulbs will work just fine
yes that is correct, i replaced all the bulbs in my boat last summer with LED's they do make a difference, and i only want to install bulbs once.
OEM bulbs are fine if you're looking for that factory stock "look" but at night time when you need to see your gauges they are barely readable. LED is the way I wish I had gone when I replaced my harness last spring. Much brighter and certainly would last longer.
