Replacing Rear Wheel Studs on '66
I've got a couple of broken studs on my right rear wheel. Has anyone had any luck pulling apart the e-brake shoes, driving the broken ones out and slipping in new ones from the back without pulling the axle shaft out?
Thanks in advance
Thanks in advance
Yes
But it involves drilling a hole where most don't want to drill because they are NCRS types and a hole would cause them to have a near nervous breakdown!
Statistical data based on 55 views and no replies, are that there are 54 of 55 that are NCRS members who gave no feedback!
Ok statistic update--
As per new views! 77/78 NCRS types!
St. Jude Donor '13-'14-'15-'16
Received 1,919 Likes
No desire to call out anyone on any side; however, the response to reply ratio in this forum, as well as many if not all forums is neither unusual nor indicative of any axes to grind, quoted comment notwithstanding. Just say in', some have reasons to comment, including slams, but most just view from the sidelines.
OP, here's a bump for you, with a meager attempt to get the topic back on track. I am no help, sorry. I have replaced many wheel studs, but none on a mid-year Corvette.
It doesn't depend on the application I prefer/the correct way is to take the axle or in this case the stub axle out and press out and in the old an new studs.
THAT'S the way to do it. Been there, done that.
Randy
Received 1,843 Likes
https://www.corvetteforum.com/forums...post1569122400
Drilling a hole may be easier but either way beats pulling the axle out.
Thanks for everyone's input... I'm going to keep an open mind but the two broken studs aren't budging so may have to pull the axle after all. Pretty sure I can pull it off but the hardest part though will be getting the bearing clearances right when it goes back together.
I had a mechanic do it for me last summer. He said he had to enlarge a hole in the splash shield then was able to get the stud started. My car is not judged so I did not care. If I recall correctly the charge was 5 hours labor. I have to take it back to him because he did not index the rotor correctly and now I cannot adjust the emergency brake
Randy
Randy
So by enlarging the hole in the splash guard, i am curious
Randy
Randy
Actually I was just funning with NCRS comments naturally so i will continue on, but then those types would need to see an official tech diagram and be told precisely where to put a figgin hole, whereas a person with good mechanical ability could rotate the spindle and see what and where is there an obstruction to pushing out the studs one at a time, threw the backside if you made a single hole, that was large enough for the stud head and big enough for whatever tool you have in your arsenal of tools, to press them back in- one at a time as you rotate the next stud to where the hole is! If anyone asks me for a diagram, then you are only qualified to pay someone for their services, who doesn't need a diagram! Maybe Corvette Restorer should get that article into print as to what not to do for their next issue! or better yet an article on how to fix such a hole if encountered on your NCRS restoration! But i can write that for the Restorer upon request, lets see find a washer that hole size (because they are already round) and if none can be found locate a slightly larger washer and drill hole larger stll, then weld washer into hole, tack weld washer center hole and grind all flat, then go take the part for replating!!!!!!
PS I would say 5 hours would have included beer!
Second PS if the studs are quality and you have a quality lug with better longer thread engagement, you can tap it in and then pull them thru from the front with a lug procedure using spray oil. force on the threads could heat up your threads and cause a failure, so I would crank them in by hand oil to cool if they are going in rough needing torque! PS a good mechanic would be following along with what I just said!
Heck if you just have to pull it all apart, because a hole is a big evil recommendation, then 7/16 studs actually have no business being on the high horsepower cars especially in consideration of modern rubber and long term ownership far exceeding GM's intent for you to trade in and buy a new model 40 years ago! Therefore if you pull it apart, put proper 1/2 studs into the spindles on a HP car or wider tired car!!!!!!!!!!
PS if the e-brake is locked up
It might just be seated wrongly, but then there could be an interference problem with the stud heads and grinding those for clearance could be something that you all should visually inspect for, if you are changing them!!!!! I am such an A-hole for wanting to help!!
