1967 L79 decode help
I am trying to purchase a 1967 L79 roadster and would like to make sure all the numbers are correct. broach marks appear correct. your help would be gratefully appreciated.
trim tag: e16 , 67 437, 418aa
s2088, 986aa
vin 194377s106327
block- 3892657, VI2I4HT
casting date- can't see
color- silver. int. teal, 4- speed, power brakes, man. steering
coupe
s2088, 986aa
vin 194377s106327
coupe
Received 6,943 Likes
2015 C2 of Year Finalist
Could you post a picture if the trim tag and engine stamp pad. That's a very odd color combo. I am a big fan of that color combo. From the numbers it sounds correct
Most of your numbers add up.
the Teal Blue trim was a recommended color with Pearl Silver.
The engine casting no. is a 67 block, and the eng stamp date of 1214 works for Jan 16 (e16) build date on Trim tag.
Only glitch I see is that the vin derivative 06327 on stamp pad would have been a Dec 66 built 67 car. Your trim tag says Jan build date.
Needs more investigation.
VIN #6327 was built approximately Dec. 21, 66, so an E16 body build date is perfect.
thank you. I was hoping that E was dec. , because that was the only glitch I was able to find.
looks like a very good 67 L79 car, in great color combo.
jump on that sucker.
