67 front spindles
67 front spindles
Are the left and right front spindles the same. The only thing I can see is A6 and B6?? Maybe it's called front knuckle...
Received 2,127 Likes
They are not interchangeable due too the tie rod arm connection bolt location. Dennis
I believe you are talking about hub that contains the studs. That can be swapped from side to side, but I wouldn't do that unless you are replacing the bearing races and bearings. Dennis
Bare spindles are the same side to side.
