Spin on filter adapter question?
Received 1,921 Likes
All;
I recently replaced the oil and filter on my "new to me" '65 327 with a spin-on adapter, for the first time.
The center threaded boss onto which the spin on filter is attached is loose, so much so that I was able to easily thread it all the way out, and could thread it so far in that it appeared to have too few threads to properly engage the filter.
In installing the new filter, I tightened it to the manufacturer's specifications. I then ran the engine (with fresh full oil, or course) and it indicated good normal pressure and no leaks.
Is this normal, or is there a capture nut or setscrew to "lock" the center threaded boss?
Thanks in advance!
Kevin
Thanks in advance!
Kevin
Kevin:
What brand adapter did you buy?? Some use red Loctite on the center threaded connection.
Larry
Larry
Re: what brand - no idea, it came on the car.
However, some red locktite sounds like a good idea.
Very likely a Mr. Gasket #1270 - that is a very popular, easy to find, adapter...
All;
Thanks in advance!
Kevin
Thanks in advance!
Kevin
never leaked on had problems ,Lock tight good idea
Careful
All;
Thanks in advance!
Kevin
Thanks in advance!
Kevin
