Help Forum How To | General Corvetteforum Questions | Feedback
Wrong file or format.
Old 01-30-2015, 07:08 PM
1955 copper
1955 copper's Avatar
2015 C1 of Year
Default Wrong file or format.
Has thing changed ??when I go to post a pic. this is what I get , never had a problem before!
1955 copper is offline
Old 01-30-2015, 10:05 PM
rich5962
rich5962's Avatar
Works for meeee! ???
rich5962 is offline
Old 01-30-2015, 10:10 PM
MarvBarrish
Support Corvetteforum!
MarvBarrish's Avatar
Check the size of the image you are trying to post. Be sure to stay small. too large will give the types of problems your are incurring.
MarvBarrish is offline
Old 01-31-2015, 05:38 AM
Kerrmudgeon
Kerrmudgeon's Avatar
Received 4,583 Likes on 2,157 Posts
C1 of Year Finalist (appearance mods) 2019
I don't like the new system either Roy, takes too long to post a pic waiting for it to load. I can type in [IMG]in front and [/IMG] at the end faster than that. Try it manually using the pic code and those two.
Kerrmudgeon is offline
Old 01-31-2015, 07:49 AM
Frankie the Fink
Frankie the Fink's Avatar
Received 7,082 Likes on 4,736 Posts
Army
That is exactly right...
Every Windows PC has MSPaint...you can open the picture in that application hit the "Resize" option along the menu bar and type in, say, 50% and "Save As" the picture under another name and reduce the size for uploading.
Frankie the Fink is offline
Old 01-31-2015, 11:27 AM
1955 copper
2015 C1 of Year
Dint do anything different but now it works ???????????????
Old 01-31-2015, 11:37 AM
rich5962
rich5962's Avatar
Roy, It was probably just a server hiccup or something......So are those the pics you wanted to post?????
Rich
p.s. you DID notice my pictures of the Sav-Ur-Life light, right? Is it still working good? I hope you didn't ever need it for a real break-down!
rich5962 is offline
Old 01-31-2015, 01:00 PM
65hihp
65hihp's Avatar
Received 3,263 Likes on 1,686 Posts
that's what you needed to post?
65hihp is online now
Old 02-01-2015, 11:31 AM
1955 copper
2015 C1 of Year
Rich
roy I still have it in my 55 and never needed it yet, my 55 never brakes down but had to do a valve job last summer on the original engine ,now has 118000 miles on it , again thanks for the Sav-Ur-Life light
Now it don't work again adding a pic. this forum works some time then not
Old 02-01-2015, 11:34 AM
rich5962
rich5962's Avatar
Roy email me the picture(s) and I'll check 'em out for you. I'll PM you my e-address. Rich
rich5962 is offline
Old 02-01-2015, 12:26 PM
rich5962
rich5962's Avatar
Roy, all 3 photos are less than 300kb, so here goes.....
All 3 uploaded fine via the "Image" clickbox at the header. Now I will try to attach them via the Advanced, Manage Attachments method....
...........and they appear to be fine, see below. I'm afraid it's something on your end, maybe your internet server is having intermittent trouble or your home internet is acting up. I've had a intermittent Cable Modem before and finally crapped out 100%, before I then figured out my in-house hardware was a problem.
Give it a few hours and if still bad you may want to call your ISP.
I'll post those pics in a new thread for you called "1955 Copper Photos" so you can write your text associated with it.
Rich
rich5962 is offline
Old 02-02-2015, 10:58 AM
1955 copper
2015 C1 of Year
Going to have a friend geek test my PC out he does it for a living. Thanks
To Wrong file or format.
Quick Reply: Wrong file or format.
