64 with upgrades
64 with upgrades
Picked up this 64 convertible project last month. Planned upgrades are a LS1 with a T56 six speed, all new gauges, Steeroids, Ididit tilt column, Vintage Air and upgraded suspension. New seats and all new interior. the paint is a two footer but very presentable and will be ok for a few years. The car was disassembled when I bought it. Many boxes came with it thankfully they labeled all the parts and bolts.
when I bought it
the new powertrain
New Procar Seats
when I bought it
the new powertrain
New Procar Seats
I would love to tackle a project like that..............but I can only own a driver. Best wishes with the build..keep posting progress pics and make sure you post lots of these (*&^%$# when things aren't going well.............................
Yes please keep posting, I am tempted to pull the original 327 an do a LS swap, can they be bolted to a factory muncie?
yes they can and still use your original clutch linkage, and this came without a motor witch is how I really liked it so my engine/trans options were wide open. it was originally a powerglide car.
Yup! Looks like that car has "good bones" for a restomod build...nice..
big hole and engine bay done
updates for today. the engine bay is all cleaned and painted ready for the LS1
making room for the T56 six speed, A T56 will not fit without raising the trans tunnel, I have read about a half inch. I did it this way so I could keep the mounts for the trim all intact and level.
Also got the gauges installed in the bezel
Dan
Going to be a nice ride when you get it all together. Keep the pics coming. I love to see a project getting completed like this.
It probably would but I had to move the engine forward more so the shifter and trans were in the correct location, that T56 is huge. I am going to try the factory corvette setup and hope the power steering will clear if not I will clearance the frame a little like the recess for the crank pulley and use the Camaro setup.
I keep trying to educate myself for this swap down the road - are you having the water pump connections done or can you buy a housing reconfigured? I really like your work!
Fwiw I would be tempted to paint the engine covers in cast aluminum! They are very cool either way you go.
