No spark troubleshooting 62
2018 C1 of Year Finalist
So far, I have checked or done the following:
Replaced the coil. Still no spark jumping off of the coil on a ground.
Replaced the brown wire in the wiring loom for the engine harness. It is connected to the ignition and connected the coil. I am bypassing the ballast since I am running a Petronix.
I do not see any spark coming off of the coil wire going to a gound.
The starter is turning over the engine. I added fuses on the brown ignition wire, black wire to the ammeter, clock and lighter. All of the fuses are good (non of them blown). The ignition wires are in the right location.
Counterclockwise... Red brown violet on back of the ignition switch. Red is connected to the single slot where brown and violet are going into double slot.
A quick check is to run a jumper from the "+" battery terminal to the "+" ignition coil terminal and see if you get the car to start; if so then you problem is back towards the ignition switch...if not, you could have a bad coil, dead Pertronix, bad ground somewhere or other wiring issues...
Buy a VOM, Volt Ohm Meter.
Inexpensive to buy easy to use.
Read up on how to use it if you haven't before. Never put it in Ohm mode on hot power connected stuff.
Doug
Doug
Received 1,843 Likes
An even quicker and more revealing check is to hood a test light to the minus side of the coil and ground the other end. Crank the engine. If you get a steady light, your ignition is good to the coil. If you get a flashing light, your Pertronix is probably good and your coil should spark to ground. If the light doesn't flash, yer Pertronix done blowed up on ya'!
Real quick and simple. No need to mess with all those jumper wires and such.
Your VOM probably would have told you coil was OK and you didn't have to replace it and saved you some money, unless you just wanted to replace it anyway.
The primary and secondary Ohms values are on the web. Obviously, an infinity reading means it is bad.
Doug
Doug
My check takes two seconds and anybody with a C1 should carry a jumper wire in the glove box for emergencies anyway. You also get to hear the car actually start instead of looking at a blinking light.
But, pick your own poison...
I honed my suggestions with a brand new car coming off the line every 45 seconds. Occasionally, one wouldn't start. Sometimes two in a row.
If you wanted to stand around with yer thumb in yer butt with a jumper wire, you'd quickly have the line shut down and find yourself on the carpet explaining why you couldn't run the place.
There is an easy way and a hard way.
PS. In all my years of tinkering with old Chevys, I've NEVER seen a bad ballast resistor. Unlike what is widely reported as a likely culprit on this forum.
So much drama. Use either method and God forbid if one takes 2 minutes longer.
We're on a tight schedule dammit!
If it was grounded, I have no idea what it would do to a Pertronix.
