carte afb 3269 vs. 3310
They are completely different designs. The AFB has no gaskets below the fuel level, has air valves above the secondary Venturi, a single fuel inlet and an aluminum body. The 3310 is a basic Holley 4bbl with vacuum secondary throttles. It has two fuel inlets, is made from cast zinc, has replaceable metering plates that disassemble from the main Venturi housing and has a few gaskets below fuel level, like fuel bowl and metering block gaskets and mounting screw washers. Having gaskets below fuel level means you gotta keep an eye on the carb for fuel leaks.
A feature on the AFB I really like is vacuum operated mixture needles. These are pulled into the main jets by manifold vacuum and lean out the fuel mixture at light part throttle. None of the Holley 4150/4160 series carbs, which the 3310 is an example, has anything like that.
Hope that helps.
Hope that helps.
I think OP was asking about CARTER 3310 vs Carter 3229
I don't know the differences, but what I suspect Mark was asking about was the difference between two different AFB carbs used in 1962:
3269 as used on 300 HP and 340 HP engines with manual transmissions
and
3310 as used on the 300 HP with Powerglide
I don't know the answer, but I hope I've clarified the question.
Steve
and
Steve
The ST-12 does not list a 3310 AFB for '62.
The differences can be amazingly subtle.
In the Specification section of the ST-12 manual the specs for the internals of the 3269 are given; if you can find the equivalent manual for whatever the 3310 fits on you can get those specs and compare the two. It may not even be enough difference to "feel" on a small block...
Hope that helps.
Hope that helps.
The metering rods on a AFB do the same thing and when the spring overcomes the engine vacuum the rod lifts out of the jet allowing more fuel to the nozzle. Good thing with the AFB is that you don't need to take the carburetor apart to tune the power enrichment. The venturi clusters usually need to be replaced to change IFR/air bleed.
I forgot the original question though so sorry if I got started..
The 3310 is set to run leaner than the 3269. The primary and secondary jets are smaller and the step up rods are larger diameter at the cruise step. Also the primary air bleed circuit is .002" smaller on the 3310. Using a 3310 on a manual trans car will cause a stumble when the throttle is initially opened. Changing the parts mentioned as well as the primary venturi clusters will duplicate the 3269's performance.
Verne
Verne
and
Steve
and
Steve
Verne
Verne
Verne
