Where to hide computer for ls swap
I have c2 with ls swap but not sure where to hide the giant computer. Wires aren't long enough to get it behind seats. Too tall to go under seat and there doesn't seem to be any space under or around dash. Hopefully I am missing some prime spot. Thanks
Doesn't the company you bought it from make 'plug/play extensions' for just such a Delimma/problem?
What if you took out the glove box liner?...
Thought of both things. Not sure it would even fit without a glove box and am going to research a extension right now. Was hoping there is some magic place to put it that I just am not seeing. You know what they say, two pairs of eyes are always better than one. Problem is I feel blind right now.
Tom. .
A good spot you might consider is the underhood area behind the left front fender. Installing cruise control in my car, the electronic control module is of fairly good size. I felt the module was too big for an under dash installation. I also didn't want to give up the glove box to accommodate the module .
Under the hood the module went. ..The mounting bracket that came with the cruise control kit was modified so that it would fit underneath the bolt head of the front left (#1?) body mount. The bracket was cut to fit. A "U" shaped channel was cut at the bracket end so it could slide under the bolt head, then tightened down.
A zipper type plastic bag was used to cover the module and wiring harness to keep dirt and moisture out.
John
John
I would seriously consider under the hood with the plugs facing a convenient way. If you dont mind the aesthetics of it under the hood you will appreciate it in the future if you ever have to diagnose a wiring problem. Trying to backprobe a connector while lying on your back on the floor board with a flashlight in your mouth and both hands deep in the backside of the dash sucks! More and more OEMs are putting the ECMs under the hood and as a driveability tech I applaud them for it.
I put mine behind the shallow glovebox you get with a Vintage Air system.
I took out the glove box liner and it's seems like the easiest spot. I can also mount the fuse box in there. All I need is a custom box liner.
I put mine against the passenger side firewall inside the engine bay. the vintage air setup had a flat side that was big enough to use some rivnuts.
Got it figured out
Fabled a bracket and took out my glove box. I just need to make a custom box now. I couldn't find the vintage air glove box. I will still have half the glove box left and easy spot to mount the fuse box. Thanks for all the ideas.
I customized the center of my dash, removed the clock and radio and installed a center vent with vintage air controls. I put the ECM in the center where the radio once was.
I have always kept them in the engine compartment, where GM put them. I never understood the need to move them inside the car. You just have to make a huge hole in the firewall for the connectors to go through, and then you have to seal the wires after the fact. On my C1 cars. I mount the ECM to the driver's side splash pan. and on my C2 cars, I mount them under the driver's side fender. Both locations make the installation invisible to the casual observer, and it does not eat up limited space in the interior.
Regards, John McGraw
