64 Coupe Gauge Cluster
Old 02-28-2015, 11:48 AM
VITIV Coupe
VITIV Coupe's Avatar
Default 64 Coupe Gauge Cluster
On my gauge cluster at the bottom, where the (3) vent cables and headlight motor switch mount, the mounting screws do not screw directly into the gauge cluster. What are the name of the clips called that attach the vent cable to gauge cluster? Does anyone have any pictures and where can I purchase them?
Old 02-28-2015, 12:30 PM
66jack
66jack's Avatar
You might be able to use these...Part #252177, or #342047, or these would be better..#282036 you can probably get them a NAPA
http://www.parts123.com/corvettecent...50g&ukey=15077
Old 02-28-2015, 12:41 PM
rccarson
rccarson's Avatar
I think you are looking for these. You can pick them up at most auto parts store.
http://www.parts123.com/corvettecent...50b&ukey=24524
Old 02-28-2015, 02:28 PM
plaidside
plaidside's Avatar
Received 1,120 Likes on 550 Posts
If you are looking for the clip with the nut attached that accept machine screws they are either called 'clip nuts' or 'J' clips.
Check out a local body supply store.
http://www.dormanproducts.com/gsearc...rd&q=clip+nuts
Joe
Old 03-01-2015, 08:13 AM
VITIV Coupe
Thanks Guys. I ended up buying the clips from Ecklers.http://www.ecklerscorvette.com/corve...1963-1967.html.
Old 03-01-2015, 08:43 AM
66jack
66jack's Avatar
Those are the wrong ones/size..your screws are a different thread count/size....those hold the cluster to the dash...
Old 03-01-2015, 10:43 AM
VITIV Coupe
Darn, I was afraid of that. Which ones are the correct ones? I only want to do this one time on my back.
Old 03-01-2015, 02:10 PM
buns
buns's Avatar
I believe that only the headlight rollover switch uses those clips. The vent cables screw directly to the dash. But if the holes are buggerd you could use those clips. Do you have a Rona nearby? Mine has a good selection of stuff like that.
Old 03-01-2015, 03:13 PM
JohnZ
Support Corvetteforum!
JohnZ's Avatar
Received 1,856 Likes on 1,099 Posts
The vent cables screw directly to the bottom flange of the cluster with self-tapping screws (no separate clips or nuts) - see your Assembly Manual, UPC 1-Asm, sheet A8.00, items #5 and #6.
The headlight rollover switch installation is shown in UPC 12, sheet B4.00, items 4-5-6; the switch ears go ABOVE the bottom flange of the cluster, and item #4 is a flat #8 Tinnerman nut.
Old 03-01-2015, 03:39 PM
VITIV Coupe
I think Bubba had previously messed with the cluster. I cannot screw the vent cables directly to the cluster, the holes are oversize. Thank you for the information John. I'm into a hunt for a good assembly manual now.
Old 03-01-2015, 04:34 PM
kingwoodvette
kingwoodvette's Avatar
It's a shame those weren't right. According to the ad you referenced, the kit had been reduced from $749.95 to $5.99!!!! What deal.
Old 03-01-2015, 04:49 PM
VITIV Coupe
Yeah, I saw that to. You mean what a misprint. lol
To 64 Coupe Gauge Cluster
Quick Reply: 64 Coupe Gauge Cluster
