Speedo does not work
Since I purchased my '56, the speedo has not work. With cable connected to both tranny and speedo, there is no movement at the speedo when driving. So to troubleshoot this problem, I was considering connecting a portable electric drill at the tranny end of cable to see if the problem lies with the cable and/or the speedo. The speedo has never be overhauled as far as I can tell. Assuming the cable/speedo are working after this test, what is there to look for on the tranny side?
Thanks,
Ron
Thanks,
Ron
Thanks,
Ron
Thanks,
Ron
Received 3,770 Likes
2023 C1 of the Year Finalist - Modified
2015 C1 of the Year Finalist
It is NOT necessary to connect a cable/drill to the speedo. Simply disconnect the cable from the back of the speedo and grasp the end of the speedo fitting with your thumb/finger and spin it. Observe the speedo needle to see if it moves up. If no movement occurs to the needle, then likely the issue is with the speedo.
