'64 removable hardtop headliner
My friend's '64 convertible has a drooping headliner on the hardtop. What is the proper way the vinyl & foam should be attached? What is glued to what? Is the foam piece available?
Verne
Verne
Verne
I just checked Corvette Central and Paragon and they say it's vinyl bonded to a plastic base. Shouldn't it be possible to reglue the vinyl back on the plastic?
New ones are only about $200. I wouldn't mess with the old one because chances are it will separate again. i got my headliner from The Hardtop Shop.
Don
Don
He's on a limited budget. Could someone actually answer my question?. 3M 8090 upholstery glue has saved many a car's vinyl from having to have it all replaced. I'm just asking if it is possible to reglue it to the plastic base from owners' previous experiences, or will it NOT take.
it is useless to do it. If it is a reproduction, you might have a chance if you keep the glue light and dry.
Thanks. I haven't seen it yet, only heard about the issue. I'll know more about what I'm dealing with after I look it over. It's a mystery for now because I'm darn sure it's the original hardtop.
Verne
Verne
2016 C2 of the Year Finalist
The rear window should be dated in the lower left corner under the word " Plexiglas" and will tell you if it is in fact a 64 top. The date will be a number for the month followed by two digit year number. For judging purposes, the date should be within a year prior to the manufacture date of the car. Dave
Received 1,044 Likes
C2 of Year Finalist (appearance mods) 2019
No matter what the date on the top is, it won't have a vinyl headliner in 64 from the factory. All headliners in 63-64 cp or convertible where a fiberglass material (like a old ceiling tile but thin) with a film of some type of paper material (also like a ceiling tile) and no one reproduces the original, no one. Not repairable either. All repros are like a hard cardboard.
When I restored my '63 hardtop a few years ago it had one the fiberglass insulated cardboard faced liners as described above. It had a leather grain impressed on the surface. The replacement was a stiff plastic backing with vinyl glued to the surface. Don't see how the original could be repaired.
Well, after some people telling me it had to be a later hardtop, I was hoping for some positive identification based on those photos. Is that trim painted the same Saddle as post-'64 Saddle?
Verne
Verne
