396 dieseling
396 dieseling
Im not much on motors. I know just enough to be dangerous. But can anybody explain why my engine will sometimes diesel (run on) a little after i turn key off. Not all the time. Sometimes.
Probably carbon buildup in the combustion chambers. It gets hot and ignites the fuel-air mix that still gets sucked in as the engine rotates down after the ignition is turned off.
What is you idle RPM?? Too high a curb idle will cause this.
Larry
Larry
First thing to check is too fast of an idle speed...you could get off easy...
If the car has an aftermarket cam in it with more duration and lift, the rear (secondary) throttle blades may need to be opened very slightly at idle to compensate and allow the primary throttle blades to be closed a bit more.
Received 1,843 Likes
