Stainless Steel Repair and Polish
Hello
I have managed to get all of the stainless steel trim pieces off of my car. I'm looking for someone who can polish and fix stainless steel. I have a 1963 vette and there is damage done from wiper blade on the lower piece and also driverside pillar. I have read some post from other threads from the past. I am also seeing the words "flash chromed" after SS is fixed and polished by some forum members.
I am looking for a someone to fix and polish my stainless steel trim and flash chrome them also. I'm confused how you can tell if its been flashed chromed?? Like a clear coating on SS trim?
One more thing someone got really excited about using ALOT silicon sealant, weather stripping glue, dum dum strip caulking. What the easiest way to strip this?
Pete
Pete
There is a gentlemen up around Daytona way that is at every NCRS meeting in Kissimmee that I've attended and his work is wonderful. He always has a white van, speaks with an accent and has his wares displayed on a tabletop and its all flawless.
Hopefully somebody can remember his info or else I'll search for his card later on. I think Space Coast Plating might do it. It'll be $$$, take forever and their quality has taken a hit lately though.
54 Vette Rod
108 N State St, Bunnell, FL 32110
(386) 586-3383
FYI (quote from a platter)
Flash Chrome Plating
We offer a flash chrome plating service based on Chromic Acid - Chromium Trioxide Flake from Elementis. Our solution is made up of 250g/l CrO3 and Sulphuric Acid at a 100:1 ratio.
Process: Flash hard chrome plating is an electrolytic process utilising a chromic acid-based electrolyte. The component requiring plating becomes the cathode and, with the passage of a DC current via anodes, chromium metal builds on the component surface.
Background: Flash hard chrome plating, also referred to as functional chrome plating, is applied as a thinner layer. It is ideal for close tolerance applications where an excessive build up of chrome is undesirable and where the requirement is to provide a durable hard wear-resisting surface.
Applications: Flash Hard Chrome plating has many typical applications, some of which are detailed below:
Wire wound rods for paper coating
Seal areas on pump or drive shafts
Conveyer guide rails and rollers
Plastic extruder screws
Hydraulic rams and cylinders
Print rollers
Tanks: We offer tank sizes up to 3.6m long.
Thickness: Coating thickness is dependent on the application and the customers’ requirements, which can normally range from 10 to 25 microns. This smaller deposit of hard chrome usually eliminates the need for a grinding operation to finish.
Hardness: Hardness is in the region of 950 - 1150HV.
Materials: Most materials can be Flash Chrome plated, including:
Steel
Stainless Steel
Cast Iron
Copper
Brass
Bronze Alloys
Nickel Alloys
Plating Vats: We have the capacity to chrome up to 3.6metres in length and if you think you may have a possible application for a component not listed, please contact us to discuss this further.
Stopping Off: Selective Hard Chrome plating can be achieved through masking with clamca wax or stopping-off lacquer.
Etching: Etching is carried in accordance with the guidance relevant to the base material being plated. All components are etched before Hard Chrome plating to provide a good key for the hard chrome deposit to be applied.
Jigging: Careful jigging is required for hard chrome plating, taking into consideration current carrying capacity and weight of component. Special attention is necessary for the plating of internal surfaces. One of the characteristics of hard chrome is its poor throwing power, therefore auxiliary anodes maybe required at strategic locations.
Print rollers
Steel
Stainless Steel
Cast Iron
Copper
Brass
Bronze Alloys
Nickel Alloys
Hi
I just got off the phone with John. The guy seemed nice and educated me on Chrome flashing. He was patient with all my questions and gave me his thoughts on Chrome Flashing. I'm going to use him to fix and buff out my stainless steel trim. Thanks for your help guys..
Much appreciated
Pete
Much appreciated
Pete
Print rollers
Steel
Stainless Steel
Cast Iron
Copper
Brass
Bronze Alloys
Nickel Alloys
Print rollers
Steel
Stainless Steel
Cast Iron
Copper
Brass
Bronze Alloys
Nickel Alloys
This sounds just like regular chrome plating to me. Do you know how "Flash Chrome Plating" is different?
Thanks again,
Yogi
Hi
Much appreciated
Pete
Much appreciated
Pete
Here is JohnZ's article explaining chrome plating:
Received 1,858 Likes
Print rollers
Steel
Stainless Steel
Cast Iron
Copper
Brass
Bronze Alloys
Nickel Alloys
Print rollers
Steel
Stainless Steel
Cast Iron
Copper
Brass
Bronze Alloys
Nickel Alloys
That's what happens when you use a quote from an unknown Internet source...
Did the polishing on both my 66 vert and 64 coupe, and will most likly do the stainless on my current 64 project.
In fact I'm glad this thread was started, I'd lost J&M's contact info.
Received 1,295 Likes
2022 C1 of the Year Finalist - Unmodified
2021 C1 of the Year Finalist - Unmodified
2019 C1 of Year Finalist (stock)
2016 C1 of Year Finalist
The local platers I've spoken with will not attempt 'flash chroming' of stainless.
There does seem to be a little confusion about what exactly it is.... and isn't.
I've heard it described as a 'quick dip in the chromium tank', but again, the local platers would not buy into that.. and the stainless steel scares them too.
Well - if you redid them yourself and didn't re-anodize them; then don't worry. They won't stay that shiny for long
