1966 dash cluster replacement
After removing my dash cluster in my 66 convertible a year ago, I'm ready to re-install it. On the back of the ignition switch there is a terminal for ground, but there is no ground wire in the connector that plugs into the switch and it doesn't appear to have ever been there. I've searched for a spare wire that might go into the connector but can't find one. The wiring diagram in the service manual shows the ground terminal on the switch but doesn't show a wire. Does anyone know if there is supposed to be a ground wire in the big plastic ignition switch connector on the 66?
Location: About 1100 miles from where I call home. Blue lives matter.
Received 5,331 Likes
This is the Cars For Sale section.
I'll move this to General discussion.
2021 C2 of the Year Finalist - Unmodified
If you're looking at a connector with nothing plugged into it, you're missing the ignition switch capacitor. It has one mounting screw on the back of the dash cluster and just plugs into that open connector. But if you're talking about an open terminal on the back of the ignition switch, this wouldn't apply. Sorry.
Ignition Switch Capacitor<br/>
St. Jude Donor '13-'14-'15-'16
DonO
66 dash replacement
Received 1,857 Likes
The black ground wire is there, and is shown in the Assembly Manual - but it doesn't connect to the ignition switch; it connects to a male spade terminal just above the tachometer.
