65-67 Unflared 15x6 vs 15x7
As far as ride height, I am a "stock height" guy. Not into lowering.
The reason for exploring 15x7 wheels is for more wheel options for my 67.
Vintage 15x6 with 3.66 backspacing is catch as catch can. The ones that do show up are usually $2000+ Torque Thrust Ds. Honestly, that is outside of my budget.
Sounds like 15x7 with a 4" BS might be worth trying....
Not much time ever, so as usual I have to be quick
Lets have a new kind of Car meet and greet where all of the guys with unusual tire/rim sizes can show up along with guys with stock configured cars who want custom rims/tire combos and guys also that just want to see what someone else's rims/tires would do for the looks of their car. Entry will require a jack and jack stands, and care in properly torqueing/lug nut installation.
Sounds like a lot of fun, and I will just sit back and watch!
Your mailbox is full. Could you please do some spring cleaning?
No!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!
After all of the research my car contacts and the guys wanting to start arguments, the upset investor crowd, the NCRS guys trying to relay how insulted they felt by me, the can i buy your parts, the sensitivities of some members and lack of realization about what was truly a joke and more scenarios, I will just keep the comms to or in the threads! heck no!! But what's up? I never mind a little side chat. As revfan can see, I may joke and such, but i sincerely would like him to find a good fit and purchase for success and i hope i have been helpful here!
Not looking to start an argument. Just thanking for the input. I already sent it on a vistor message to you...
Received 1,240 Likes
2022 Corvette of the Year Finalist -- Modified
2021 C2 of the Year Winner - Modified
2021 C1 of the Year Winner - Modified
2020 Corvette of the Year (stock)
C2 of Year Winner (stock) 2019
2017 C1 of the Year Finalist
Rex knows i love his tastes in cars! I want to be him when it comes to Corvettes!
And the rims that excite me, usually are the ones where people not only want what's in my wallet, but also expect me to trade my girlfriend or worse to get them my first born child as part of the deal. So Rex what would you take for those real MAGS? and you had better not answer that, because I won't want to be you anymore if you answer that one!
I have to go watch my Gold dredging show now. derek out!
PS Rex my pet peeve, I know I could look it up if I wasn't all horizontal on my sofa tonight being super lazy, but WHERE IS YOUR BS on yourv rims for these other guys? Smile thing here! Thumbs up thing too!
I don't know how someone can get a message thru, but I got it.
Now thw gold show!
PS if you guys buy rims that suck, if you ask me to be honest i would tell you!! Hide under chair thing here!
#33
Breaking it down #1
Drum brakes, more clearance than discs! 15x7 common 3-3/4 BS is easy
#34
Breaking it down #2
I believe that should work. I have 16x8 wheels with 4 1/2" backspace which means zero offset. The wheels are centered. A 15x7 with 4" backspace also has a zero offset. The outside of your wheels will them be 1/2" inside where mine are, and the inside of your wheels will be 1/2" further away from the inner fender than mine.
You still can't go wild with tires, but I would think you should be OK.
On these 16x8's they would have 3/4 inch more than the base inward! The 8's are one inch bigger than a 7 inch rim, so you have 1/4 more if you just take the rim only outward. The 16 gives more clearance on the ID, but not enough to leave the parking brake cable be. At 17, guys don't have that problem it seems. So why is 1/4 outward working, the 16's have a shorter aspect ration (shorter side wall- therefore grab that size tire OD should be looked up, but without checking I would bet it is a smaller OD tire. It clears??? BC has a stiffer better handling type suspension, hold it off of the fender better, but I bet if putting suspension to the limit, clearance is close.
I would say this is the max, but it needed mods and probably wouldn't on some cars that aren't as square or have softer ssuspensions or worn springs!
#35
Breaking it down #3
Compare to base 15x7 3-3/4, would have 1/4 less clearance to the outside than the 16x7 and a 1/4 inch more clearance to the inside than the 16x7.
Guys I don't have all night, so i will post up a picture, let me load it. I said make a template, get some graph paper or at least lined paper! Do the same for the tires adding those over this simple rim diagram!
#36
Rims Lesson 101
Each line is an inch! A visual should help especially if thinking impaired like me tonight!
I tossed my back this week, and haven't even opened my Ebay scores received in the mail yet! Later!
#37
What is the best BS number for a 15x6 on a '67 disc brake car fitment? Again, thanks for all your input.
Also, what are the BS of your magnesium 15x6's, Dr. L88?
#38
If it helps any, I have a '64 with stock suspension that has 15x8 Cragars on it. They list this rim as 4 1/8 backspace (I get 4 1/4 when I measure) and they fit the car but do not appear to have any extra room and the drivers side rear rim rub the spring when the suspension is slack. It has 235/60R15 BFG's on it. I just converted to factory disc brakes on the front and the Cragars hit the calipers. I just ordered a new set of 15x7 wheels, I went with a no-name copy of an American Racing Torq Thrust because they offer it in a 4" backspace instead of 3 3/4 and I intend to use my same tires as they are brand new. My wheels will be here Monday, I'll keep you posted.
#39
JC
I believe the original ralleys for 67 were 15x6 with 3.66" back spacing. I don't know how much higher in Back Spacing you can go though.... and I am not sure how low will work either. 3.5"? 4"?
#40
Great fitment on this super cool car! We just need to figure out the conversion from race sizes to a street tire. The Goodyear racing tire website has spec dimensions on their offerings. You can see Rex put in some extra Castor on his alignment and the fenders size the fenders appropriately with the top north pole of the tire perfect relationship to the fender and good for the turning radius!
Here's a shot of the stance with the race tires........................looks pretty cool but the ride on 50 year old race tires leaves a lot to be desired.
