Finally able to purchase a C2
thanks guys appreciate the comments, question I bought oil cap correct fuel filter and bracket, battery tray hold down j bolts, radiator cap, floor mats little things that are missing or rigged, installed said items good servicing and drive it. my question is, the rear axle back exhaust is junk, it needs to be replaced asap, I love the side pipes, i know 64 did not have them but i really like them, I have been told by two people to not put pipes on that car? It would be a kit from allans. any body have thoughts on that?
And he is in TN... hmmmm.... the Tennessee Corvette Mafia...
Enjoy while you can.
Received 2,688 Likes
Ohio Events Coordinator
C2 of Year Finalist (stock) 2019
St. Jude Donor '14-'15-'16-'17-‘18-'19-'20-'21-'22-'23-'24
Welcome to the club. Enjoy em while you can
if they keep raising taxes on small companies, being in the mafia.. makes sense sometimes. I had a good year hence buying the car. man they want a lot of money. anyway i did replace things listed above, set timing and dwell and carb, sounds and revs so much better very happy. Need to run out or drain the 87 octane. I put 5 gallons 93 and 5 gallons rocket racing fuel 106 in my 69 camaro. gonna try that for a tank, my 69 loves it.
Before you even think about do-dads like side exhausts you pull those wheels off of all four corners and examine those old drum brakes. They may 'feel' fine but be "on the verge" of major (and exciting) issues...
First thing I did on my '63 and it was a good thing. Must have been 1/2" of built up crud all over every wheel and two wheel cylinders had fluid in the rubber end cups.
Wound up putting in all new brake hoses, shoes, spring kits, self adjusters, wheel cylinders on all four corners and flushing a couple quarts of Campbell soup-looking old brake fluid out of the system!!
Next grab that clutch pedal with your hand and give it a good side-to-side wag; any play there and the weld at the top of the pedal arm is busted. Have to deal with that ASAP.
These things will put you on foot....tatty exhausts prob won't...
#34
I had already started the brakes and draining all fluid when I started this thread, done today. correct fuel filter assembly. battery tray was a pita!
Question, I was going to get a key made for the alarm, it works but it is a 1 inch push button mounted by the e-brake handle, I am sure it was installed in a different way? I kinda like it being era correct. does anyone know the correct way or take it out and throw it away?
#35
Gary
#36
That alarm is an add on by some PO. I had the same set up on my car when I first bought it. They did crap like that (drilling a hole to mount a lock, which I assume is what's on your D/S fender) back in the day before they came out with keyless alarm systems. I'm not sure what else you mean by the push button switch though. I ditched mine, had the hole glassed in and re-sprayed to match.
Gary
Gary
#37
That's fugly - it would have to come out if it were me. Its apparently a panic button and if its a normally open switch just cut and tape off the wires individually; if its a normally closed switch then the alarm would sound if the wires are cut and you'd have to connect them together and tape them off...
#38
#39
side pipes
Allens Stainless sells what they call "Ultra Quit" (I believe). I put their 2 1/2" aluminized ones on my car and they sound great without pissing off all the neighbors, and the cops. They've got just enough hot rod rumble and you can still hear the radio. Not to **** anybody off, but the N11 off road original sound are obnoxious on the street. They belong on the track as their name implies.
Ray
Ray
#40
