M-22 rebuild
M-22 rebuild
After looking for more than a year for an M-22 that would work for my '67 435 hp coupe I have decided to build my own. I probably checked out 100 transmissions during the interim and many were not M-22's at all or were M-22's that had been rebuilt with non helical gears.
Anyway i am starting with an 010 main case dated January 24, 1967 to use with my March 17, 1967 build date.
I have decided to buy Italian gears and a steel versus aluminum rear bearing retainer but could use some help in deciding what else to buy.
I will be power shifting this transmission from time to time so I want to build a tranny that will withstand high rpm shifts.
Location: About 1100 miles from where I call home. Blue lives matter.
Received 5,321 Likes
Moving thread to General Discussion
Call Autogear, they are the ones who had the Italian Masiero gear sets made. They can tell you every thing you need to know about your transmission and can supply the parts. 1-800-634-3001
5speeds.com
You may want to contact 5speeds.com .
You will be talking right to the main man , not a salesman .
I have used him twice for advice and parts and highly recommend him.
Bill
Bill
Received 3,766 Likes
2023 C1 of the Year Finalist - Modified
2015 C1 of the Year Finalist
As to ways to drill out cases to create m-22 look alikes many things can be faked but my knowing that this 010 case that I am using was an m-22 when built makes a difference to me.
There were no designation's until 1969..
Use torque lock sliders! Any tranny place you call, will know what they are.
I use them in all my Muncie rebuilds.
My 69 Z28, with an M22 has a roller fist gear also. I am not easy on it by any means and it has had its share of 7800 rpm powershifts!
Good luck.
How do you know it wasn't drilled prior to you acquiring it??
Good luck.
Good luck.
Unfortunately, the internals were wasted but the main case is crack free and has no welded ears.
Thank you for your input and 7800 is a lot of rpm even for a 302!
The reason I know it is a real M-22 is only because the tranny came out of a '67 big block Chevelle that I am acquainted with history-wise.
Well Im a terrible salesman; but Im a good product rep LOL. If you want to talk to the guy who designs our stuff; thats George. Send an email or call the number posted above.
The "Supercase" is much stronger than a factory case. It is 356-T6 aircraft-grade aluminum; cast in PA and machined in-house here in Syracuse NY. The ears are reinforced, the front wall is .150" thicker to allow for more support and a larger industry-standard 307-series ball bearing; instead of the narrow, hard to find Muncie-only ball bearing.
If you're using a high quality gearset, you don't need Torque Locks in our opinion. They shift a bit slower because you have to overcome the back taper on the splines. Tighter fitting synchros are the answer. I'd also recommend a set of the forged bronze synchro rings, not the cheap cast ones. Id also recommend a set of the USA made steel forks, not the cheap cast iron ones. If you have some extra cash, either refurbishing your sidecover, or going to a new aftermarket one is money very well spent.
At your performance level, perhaps going to a 26 spline input for the gearset is advisable. The gearset would cost about the same, but you have a much larger safety margin. The Ductile Iron midplate for that kind of RPM would be required. Theres also a spacer plate to put the larger bearing in a factory case. More load bearing capacity, cheaper, easier to find bearing. Lastly there are caged needle bearings for the cluster gear instead of loose pins.
5speeds.com is our highest volume distributor. Other large ones would be Jodys Transmission and Midwest Muncies. But there might be a smaller one closer to you. I can check if you like.
Did you use a DATE CODED threading device ? Such a simple solution gets wrapped up in numbers, letters and horse power designations. It's a transmission component rebuild. They were made to be serviced and abused frequently.
Received 3,443 Likes
Thanks for that post, Autogear. That's a bunch of really good information to have, all in a nutshell. Guy over on the Pontiac GTO forum is asking questions.....I'll mention you guys.
