1960 Carpet Install Questions
Well I have removed my interior and trying to get the carpet installed. I'm having a problem with fitting the middle section. First, I have ACC carpet so that may help with advice. Do I need to trim the carpet around the waterfall or is there a trick to getting it under there? I get it under there pretty good, but it leaves a cavity back where the hump gets wide close to the ash tray and shifter. If I push it so if fits good back there and work it forward I need to get about 2" under the waterfall or trim it?
Tom
From your picture, it appears that you have the middle piece too far forward. It should come up to the console and then your stainless trim will hold it down correctly.
I said waterfall, but I meant up by the clock. Does that look right as far as trimming up by the clock? Or is there a way to cram that carpet under neath? My watefrall piece is fine. Thanks.
It is possible that ACC carpets have a "one size fits all" for '58 to '62 Corvettes.
Here is a shot from my 60 the day of the "barn find". It is original carpet that has never been out. You can use this as a guide as to where the rear of the front piece falls.
I don't think you should have to do much trimming, certainly not 2" worth. That would be a lot of wasted material for the carpet manufacturer.......
Found another pic that might help also...
Tom
Tom
Just my opinion, but if those "humps" are not large, I would just put a little glue in those two areas where your finger was pointing and put some heavy objects to hold them down while the glue takes hold. As Thoyer said, it is unlikely that ACC left that much material at the forward edge of the center piece that you would have to trim it.
If Frankie is monitoring this thread, I'm sure he would have some input.
Al Knoch says that you should use the seams as a locating point. The end of the seam should be on the corner of the tunnel. It's a little hard to visualize and this may not be the best picture but if you feel the tunnel it'll become obvious.
You can actually feel these two corners better than you can see them. Those are the locating points. Everything should fall into place from that point on. At least it did with me.
Now this is a '58 and the carpet is from Al Knoch so all bets are off as regarding your install. Just one more idea here.
Richard Newton
Richard Newton
I've done 3 ACC 59-61 carpet sets in the last few years. I had to trim a substantial amount at the entire "U" shaped perimeter edge of the clock console for proper fit.
Rich
p.s. my biggest headache was the drivers side floor area where it fits to the sill step. 3 sets were cut wrong(too long to the sill step). I returned one, they fixed it, then another was for a racecar with a modified tunnel/floor so it didn't matter, then one for another '59 had the same problem. That one I cut and re-stitched myself. I stopped buying ACC 58-62 carpets for that reason. 3 strikes.........OUT.
Rich
It just takes some finesse -- trim too much and you'll have a gap at the chrome "U" horseshoe; not enough then you'll have stray carpet fiber sticking up over the horseshoe. Locate the optimal position of the piece on the tranny tunnel, then cut a hole for the shifter area (CAREFULLY working from the center outward). In the same manner make a hole for the ashtray then push the ashtray down into the carpet hole to "lock" the carpet in place while you trim for the center console.
Make sure you have those side sill area wire covers or you'll never get a good transition at the floor where the carpet must transition upward to the sill. These tend to rust out but are available in repro form.
Thanks for the help everyone and thanks Frankie for confirming what I thought about having to trim. I read and read and read yesterday about how ACC was almost a perfect fit and I really should not have to trim anything. So it's frustrating when
a) you have a lack of confidence
b) my carpet seemed to be not fitting like 99% of what I was reading.
Well I'm not a drinking man, but I could have used a few shots before I took a knife to my carpet this morning, but I think it worked out pretty good even with the help from my assistant
Now I will be moving on to the last 2 pieces.
Received 6,530 Likes
C2 of Year Finalist (track prepared) 2019
What a cutie! She is definitely the reason you fixed it. Young ladies know best!
Rich
p.s. Jason, when you set the DS carpet in position, pay close attention to the slit where the gas pedal studs are, and the relation to thebottom edge of the firewall insulation before you trim out the Dimmer Switch. ACC had problems with that side carpet a while ago as I mentioned. I sure hope they fixed it. It was 1 1/2" too long and wouldn't meet the sill step properly.
Here are some photos to reference on a '59 set. Some pics comparing to old DS piece that fit against the ACC piece.
Rich
