corvette 427-425 hp short block coupe or rag top ??
hi guys , I have a corvette 427-425 hp short block is there a way to find out whether this engine came out of a coupe or convertible ??
pleas post grumpy
pleas post grumpy
Received 7,000 Likes
2015 C2 of Year Finalist
Nope
Grumpy - you do realize that everyone who has an old Chevy block believes it came out of a Corvette. If this 427 came out of a Corvette it will have a Corvette VIN on the stamp pad. Otherwise it's a Chevrolet motor - not a Corvette motor.
Grumpy, just post a picture of the stamp pad and someone will surely tell you more about your engine than you currently know...
http://www.angelfire.com/fl/procrast...n/stampbbc.htm
Good luck... GUSTO
Good luck... GUSTO
hi guys , that engine block got heavier than the last time I lifted it.
heres what I have TO608IP61241xx
casting #3869942
sorry did not look for casting dates, grumpy
casting #3869942
Good luck... GUSTO
Good luck... GUSTO
Grumpy - Not sure if you've seen the C2registry.org site or not but folks with midyears do list their cars on that site by VIN. There are only two 66's with VIN's starting with '241xx' and one of them is a 425 horse 427 but indicates they have the matching number engine and their date is a bit ahead of yours...'T0602IP'. Any overbore indicated on the piston tops?
Mike T - Prescott AZ
hi Mike , this engine has been sitting in my garage since about 1973, the former owner dropped a value and bent a rod , motor was pulled a at a local gm dealership and replace , a mechanic friend grabbed the short block [ rods, block & crank ]and now is mine and a few mice who built a nest inside.
, low miles and one over rev, grumpy
1973
1973
Of course every once in awhile a Corvette motor does turn up. Good luck finding the original car. it's probably still around with a 427/425 being represented as an original motor car.
hi guys , I am new at this , what part of TO608IP61241xx
is the vin number of the 1966 corvette I am seeking ???
sorry to be a pest , i also have the flu bug going around , many thanks, grumpy
Grumpy the only difference in the two vin options is the fourth digit, vin will be either 194676S1241xx or 194376S1241xx. Spend the money on a NCRS shipping data report. submit either one of the above vin's. If you request it with the fourth digit in error the report will provide the vin of record by GM with the correct digit at least it used too.
hi , I thought GM lost those records long ago ????
how do I proceed, you can pm me and I will give you me direct email.
I have many questions and promise not to be a pest, many thanks, grumpy
