Re-chrome of instrument cluster
Thanks,
I read the other tread and said thanks to the other guys, forgetting that I was on another tread. Dropped it off this morning at D&D Plating in Prov, RI. Found it on line with a lot of really good reviews. Told me $200 and I'd have it back in 2 weeks.
raylag64, When I did my '67 back in 2003 my cluster was fine however, my console needed chroming. When I got it back from the plater naturally the black needed to be done. I carefully taped it off and sanded the black areas with 600 wet/dry. Re-taped then sprayed two light coats of self etching primer. When that dried I applied two coats of Krylon semi flat black. As stated that was done in 2003 and it still looks great today.
Good Luck
Earl
Good Luck
Earl
