Fuel Gage Problem
Fuel Gage Problem
Just started this spring and it worked great last season
The fuel gage stays on empty,,, when i turn the ignition it will move about a 1/8 or so,,, and yes i just filled the tank
I cleaned the grounds,,, seems there is two on there with one running straight to the battery
not sure what the problem is and i am mechanically inclined but not so much great on the sparky side
1962 corvette
would appreciate ant tips
Thx
Steve
1962 corvette
Thx
Steve
1962 corvette
Thx
Steve
1962 corvette
Thx
Steve
My fuel gauge was doing the same thing on my 61 b4 I sold it. Without the help of John's article. I jumped right into taking the fuel sending unit out of the tank. I removed the float and placed it in very hot water looking for a leak. Sure enough I saw some bubbles. BINGO, got it.
Now I could have done one of two things.
Order a new one, or to save a few bucks solder the area where the bubbles came from. If you decide to do the second option be sure to clean the area with light weight sanding paper, rub lightly. And make sure all the gas/water is out of the float.
Thx... I should have thought of that,,, I had that same problem with a 29 Model A,,, soldered it and all was good again
Thank You
I removed the sending unit today and found a leak in the float so tiny it was though to see without magnifying glass... could hear and feel the gas in it when i shook it
got the gas out and soldered it up,,, my gas gauge works great now
Thx
Steve
Thx
Steve
George.
