1965 coupe back end sits low. Any suggestions?
The back end of my 1965 coupe sits a little low. I have old air shocks that need replacing. Before I do that can anyone give me some advise on what I should do? Before I buy new air shocks. Any suggestions on what air shocks to get.
Thanks.
Rob.
Thanks.
Rob.
Check the condition of the rubber parts. A spring rebuild or replacement many be needed.
Larry
Rob - I'd have to agree with Larry, good chance your rear spring is 'kaput'. Can you post up a pic of your rear spring? If it's flat with no arch noticeable, time to replace it. Sounds like the air shocks were there as a substitute for a decent rear spring, unless you are running big tires on the back.
Mike T - Prescott AZ
Thanks Larry I will look into the springs. The car had a non original 396 in it when we bought it. We have replaced that with the original 327. Maybe the previous owner added big block springs ? I'm not sure how to determine what front springs I have.
Thanks. Rob
Thanks. Rob
Count the rear spring leaves also, and let us know what you have. Either nine (9) or seven (7)…….unless you have a fiberglass one piece aftermarket spring.
Larry
I can’t think of a reason why you would want to put new air shocks on it. As the others have said, check out your rear spring and suspension components. Your AIM will give you the methodology and dimensions to check your suspension height. It’s UPC 4, sheet B5 in the ’67 AIM.
Someone (Bubba) had used air shocks on my car at some point too. It had hydro shocks when I bought but when doing a carpet kit I found the little plastic hoses and hidden valve. Never had a trailer hitch either.
Gary
Gary
Received 6,929 Likes
2015 C2 of Year Finalist
Same with my 65. I found the little valve in the jack storage area and the tubing through drilled holes!!
My valve was in the jack storage compartment also. It looks like returning to OEM will be in my future. Thanks for all the input guys. Here are some before and after shots of my build. I have had the car for 30 years and after the accident in the rain. It has sat in the garage for the past 20 years. And I finally am getting it back on the road!!!!
Air shocks likely if a trailer was pulled.
Also back in the mid-1960's the factory SuperStock guys had their cars set up higher than normal. Many people liked this look and did likewise to their daily drivers and hotrods. Air shocks was one easy way to lift the back. Different springs or spring spacers were used on the front.
The MOPAR guys had it easy for the front, and just tightened the bolts up on the front torsion bars.
FWIW
Larry
FWIW
Larry
Very nice job Rob!
Gary
BTW, you, me and 5thvet must have had the same installer, as mine were placed in exact the same areas.
Gary
