I am the proud new owner of a 54
I once saw an original owner 54 that was purchased in 55 I believe in Maryland. This was about twenty five years ago and I've since forgotten how many miles it had, but it was less than 20,000 and the car looked simply incredible.
You may want to check the Tach rev counter to give some validation to the actual mileage. Lower mileage would tend to show a very low reading on the counter since the old 6-cly would not have been running that much. I had the same question on my car - if it had turned over the 100,000 mile or not. There was a posting a couple years ago that someone had provided a formula for the tach reading, comparing it to a mileage reading of either 55,000 miles or 155,000 miles, tire size etc. Helped me to put that question to rest in my mind on the actual mileage of my car. Good Luck and post more photos of the engine compartment.....what are the numbers off of the engine block. So many of the old stovebolts were jerked out in favor of a V-8 when they were available hence any true survivor with the factory 6 is a great find!!!
John Lanning
#068
John Lanning
#068
The seller told me the hub caps were special option. My friend/seller said they are original to this car. Is it possible because it was built so late in 54.?
Wheel Covers aka Hub Caps
Not sure but they probably were. Some of the tri-5 guys will pipe up but, as memory serves those hub caps were an option on the '54 passenger cars and were carried over to the 55's. Great find BTW.
Good Luck
Earl
Good Luck
Earl
I was just adding in my $.02 worth.
Two Corvettes keeps me hopping; don't need (or want) a third one
#33
Received 6,528 Likes
C2 of Year Finalist (track prepared) 2019
#34
GM offered two accessory from the original factory wheels or hub cap ,your S/S wire wheel hub caps and these real wire wheels. Many dealers added ether giving the Corvette or Car a more sporty look.
#35
#37
#39
#40
You were fortunate to get as much trim as you did. Good for you!
The CHEVROLET side script is NOT a Corvette item. Those are replacement parts and are not the same. The mounting pins are in different places.
The correct CHEVROLET side script is available.
Congrats on a nice project car.
