'60 Vette on ebay
'60 Vette on ebay
Hard to find a decent car for this price ($34,900 buy it now)... frame looks solid, body not too bad... car looks complete, comes with correct date coded block...
http://www.ebay.com/itm/111650438338?forcerRptr=true&item=111650438338&viewitem=
Chevrolet Corvette Base Convertible 2 Door | eBay
There's a 1961 listed from Orange County, CA, on it's second trip on ebay. I went to look at it and the description is short several expensive facts about the car.
Wow.. third time that it did not sell? Yeah... that is interesting... what expensive facts missing stands out to you? Was thinking about showing this one to my dad... thanks!
A lot of these sellers do themselves no favors with their gimpy ads. Also, some cars just seem to bounce around on the auction sites because they are uninspiring or something. I don't quite get it either....
Maybe buyers are thinking it needs another $20K to make it a high-quality driver then you will be at the upper edge of what an NOM driver is worth....who knows ??
Lots going on with this one. Quick scan of the pics makes you wonder what lies beneath.....
Pass side wiper, antenna mount, trunk emblem, trunk lid alignment (as FTF pointed out), no arm rests, door panels funky, dash pad / white painted gauges a mess, fuel line routing (seriously?), water temp sender in top of water pump, valve cover oil fill cap jammed into oil fill tube (killer), wrong carb, no fan shroud....................
Could be a few of the reasons it has not sold,
Tom
Tom
Tom
Tom
160
I don't think the hose is clamped to the fitting. Looks like the fitting has been pushed back to allow the hose to fit over the end of the fuel line. Hopefully they didn't cut the flare off of the end of the fuel line, otherwise there will be fuel leaks......
Either way, 34k is strong money for that car....... again IMHO.
Tom
Says Sold now.
That car is a complete rust bucket. Junk. Look at the frame rails. As Popchevy said, the entire frame has been plated over, which causes even more rust. Look at the scale on the steering column. I guarantee that the control arms are shot, and the rocker supports, and hinge supports are also rusted away. I wouldn't touch that car for 10K.
Mike Coletta
Mike Coletta
The steering column mast cover is a mess and I've never seen rust like that.
I don't see what everybody else is seeing on the frame at all...
Not sure how many conclusions you can draw from two crappy pictures - either way.
Frank,
Look at the two pictures showing the frame rails. There is a 1/8" steel plate welded to the bottom of the frame (probably the sides also). You can clearly see the "poop" welding along the edges. If you'll look at the frame on your 61, you'll see that it is made in two "C" sections, with a weld seam stitched along the bottom and the top.
When plates are added the way that they were done here, it was only done for one reason.....to cover up rust. Then what happens is the the moisture is trapped between the "plates" and the original frame metal, and that causes the frame to rot away. That's really a bad one.
Roll your mouse over the picture, and it magnifies it.
I see it now. Its the areas at the red arrows ? Right ?
Yeah that's a major issue...
Yes, my '61 has the two C channels tacked on both top and bottom.
I should have caught that when looking at the pics...of course it would have been clear with an eyeball, close-up inspection.
