c2 headlight
c2 headlight
I have a 65 that didn't have any headlights , so i didn't know where all the parts went . I have looked at the web youtube assembly and i am not sure where the ball seal washer goes. Which side of the inner fiberglass reinforcement will the seal washer be located.
Try this Video...
This should help you with all your questions...
Starts after 30 second intro...
I thought the video would help...
In the AIM...upc 12...A2 and A3...
Starting from outside...spacer/set screw...support, bearing/ball, felt, retainer, washer...
Starting from inside...Support, bearing/ball, felt, retainer, washer..
Hope this helps...
Hope this helps...
so in my photo of the ball seal washer, should it be on the other side of the fiberglass inner reinforcement , as it is seen in my photo also .
Yes...I see now what your asking...
Everything should be encapsulated within the support, but in the order in which i noted from the AIM...and then the 3 bolts hold it all in place...
