Insulating Inside of Heater Box
I am just finishing up the heater box on my 65 project and I am looking at the problem of heat inside the car. Before I started the restoration, I had an inline shut-off valve in the heater hose and I did notice that it helped. My problem is that I don't want a valve showing in the engine bay now that everything else has been put back to stock. In looking at the heater box, I see that there is a lot of room between the core and the sides of the box. Has anyone tried using thin heat insulation inside the box to reduce interior heat? I have some firewall heat insulation from another project that is very thin. Just doing some home experiments on the stuff, it seems to really reduce heat transfer. I know that it will not be as good as a shut-off valve, but I thought that it might be worth it while I am inside the box. Am I missing something here or does this sound like a reasonable option?
Thanks,
Doc
Thanks,
Doc
I am interested in what others think also...
Sounds plausible in keeping the heat transfer to the cabin, especially the pass side of car...
The only downside I see, is if the material came loose and cut off air flow to/around heater core...
You could try some Frost King SA insulation from Home Depot or some EZCool insulation which needs an adhesive applied. Both are probably about 1/8 t0 3/16 inch thick but the EZCool is pretty compressible.
The stuff that I have is about 1/8 thick and it is designed for firewall insulation. It has a sticky back, but I think that I should use some additional contact cement to make sure that it stays in place. I know that the box obviously gets warm inside and that tends to break down adhesive. I guess that there is no real downside, so I think I will go for it. Thanks for the feedback.
Doc
Doc
Thanks,
Doc
Thanks,
Doc
I worked on this yesterday and I believe that it will work. I did an unscientific test with my heat gun. I used my temp gun to measure the outside surface temp with the heat gun pointed at the inside of the box. After I glued the insulation around the sides of the box where the core sits, the outside temp was much lower, which was not a big surprise. It may not be a big deal, but the cost was zero and I can't see how it will hurt. I thought about blocking off one hose, but I have read that GM wanted to have flow to the core as a way to increase cooling capacity. I live in coastal California, so I don't see many hot days. I do see some cool evenings and mornings that make a working heater a nice option. The car is still a long way from finished, so I will not have the final result for a while. Thanks as always for the input, this group is a great asset when working on these cars.
Doc
Doc
