Quick Q? Driveshaft/Transmission Yoke Removal
Mine starts to slide out... about 3 inches or so and then stops. Do you just yank on it to get it out or is there a trick?
I have a new driveshaft/yoke that I am putting in, and the old shaft is out but the yoke is still in.
I don't want any more co$tly mistakes if I can avoid them.
Thanks!
*edit*
A buddy said, "just pull it"
And man, I am putting some effort in to it (or as much as I can with the car up on jack stands) and it gets to that 3 inch mark and doesn't want to come out.
Thanks!
*edit*
Unless the seal is interfering with removal, there is damage or a burr on the splines OR there is some sort of suction taking place it should slide straight out; my '61 does at least.
That yoke is like a mini air pump when piston-ing in and out going down the road over bumps and I had a theory that that is what blew the Welch plug out of the Keisler yokes.
Thanks!
*edit*
Thanks!
*edit*
Does the yoke still feel as if it is on the output shaft or can you move it around , with the rear seal holding end of yoke?
I push it back in and turn it a bit and try it again.... and I mean I yank/pry/pull for all I am worth...
Sounds like it is hung up on rear seal. When you say you can move (rotate) is the tranny gears turning? When you pull it out is it still on shaft? Or stuck on seal, if seal , you need to pull it out with seal coming along , as there is a problem with yoke or seal , pull real hard , if off shaft
It also could be some wear on the yoke from the rear bushing, creating a shoulder that is catching on the bushing or the seal. If I understand correctly it's locking up the transmission from rotating so there must be some interference with the bushing. It should pull out with some effort. Even if it tears the seal that's pretty simple to change out. Does the yoke have some lateral play in it (to the side) when pushed back into position? If so you may need a new bushing and/or yoke also.
I hate to even suggest it but is there some way to get a bar through the front U-joint gap and try carefully leveraging rearward against some strong pivot point ?
Sigh....
Car show season starts next weekend, and It'd take 10-14 days to get a new bushing/seal combo.
I might just use the old drive-shaft and save the switch to new shaft/seal/bushing for a rainy day after the parts come in.
Received 1,843 Likes
Get a steel hammer and drive it out of the transmission. You have nothing to lose but a seal and a bushing.
Build up your energy while you're waiting on a rainy day.
Why are you changing it out ?
Leaking, out-of-balance, bad U-joints, wrong part ?
Maybe its one of those "best left alone" things...
Got a restored/balanced drive shaft & Yoke... kind of a shame to not put it on after all that.
Was it giving me problems?
No.
So back in it went.
Did you check the yoke for side play when pushed back in? If there is play in it, it may cause you some driveline vibration. But other than that no harm. As MikeM suggested, when you get ready to change it out a slide hammer or few blows with a 5lb hammer should get it out. You might get lucky and the bushing slide out with it - but probably not.
When I pushed it back in, it was pretty solid without movement.
I'll go ahead an order the bushing & Seal... to be ready when needed.
Thanks guys!
Thanks guys!
Well if you follow MikeM's approach with Pertronix you should keep that spare driveshaft behind the seat somewhere.....ya just never know !
It that's what it is, the hammer is your best friend. If the splines are twisted, that'll cause U-joint failure sooner than later.
If you car has a Muncie, which I think it does, 67 right?!? It is the bushing in the back of the tranny. There is a bushing in the tail shaft that holds the yoke stable much like an input bushing in the back of the crank. If those aren't replaced over time they wear grooves in them and he looser they get the bigger the grooves. You will need to replace the bushing and the rear seal. Now for the hard part. Slide the shaft in and out very fast with a banging action at the end of the pull out. It should pop loose. If not hammer and pry bar!
To replace the bushing, you need to remove the tranny.. PROJECT CREEP!! take the tail shaft off and drive the bushing out. Reinstall new bushing, then put the tranny back together. Wait until it's in the car to reinstall the seal. You will get oily.. But it will be done right.. PM me if you want further instructions should you decide to go that route..
Good luck
Tony
Good luck
Tony
Yes... its a Muncie (67 Convertible)
ugghhh....
Sounds like next winters project.
I have to replace my leaking rear seal on my Muncie M20 next week. I hope mine just slides out. The car is on stands and I'm 64 and I don't feel like wrestling with anything anymore.
