Understanding Ohm Readings
I need help with ballast resistor ohm readings. Old resistor read 1.9 ohms and I was told I needed a .8 ohm resistor for my MSD Blaster 2 coil. Went to NAPA and picked up Echlin resistor #1CR5500 which is supposed to be rated at .85 ohms. I get a reading of 5.5 on my meter. What gives?
I am going to throw out a guess that the Echlin number 5500 means 5.5 ohms,and you were given the wrong resistor.
Doug
Doug
John
Ballast resistors are designed to get hot..........that's why they are encased in ceramic. Resistance increases with temperature.
Ballast resistors' rated resistance is measured at a specific temperature.
OK, but that means that at operating temps the resistance would increase above the already too high 5.5 ohm reading, true? I am confused!
The ballast is wire wound internally, the ceramic disperses the heat. The resistance will change very little (almost zero change) at any temperature. You should measure .8 ohms if your meter is correct and your leads are making good contact so as not to create resistance. A reading of 5.5 ohms on a .8 ohm resistor is not correct. If your other resistor measures correctly with your ohmmeter, the new resistor is not correct.
I can only assume at this point that old ballast resistor reading was correct, or my meter is wrong. I'll check back with Napa to try to confirm what's right. This should be fun......
Check your ohmmeter by shorting the two leads together and see how close to zero you get, remeasure the resistor and post back what you find.
I get a reading of .2 on meter with leads shorted out. I know it should zero out, but doesn't at lowest setting of 200 ohms. Resistor reads 5.5 which I guess should be 5.3 corrected. Just returned from Napa, they gave me copy of spec sheet on echlin part, shows .85 ohm rating. I am calling echlin help line tomorrow - either got miss packed or they know something I don't. Stay tuned.
I can't imagine why any ballast resistor would be 5.5 ohms. You would get very little voltage drop at the coil and almost all at the resistor. I don't think the car would even run. Let's see what they say.
Why not just buy this one. It is the one MSD recommends for your coil.
http://www.autozone.com/batteries-st...sistor/139539/
http://www.summitracing.com/parts/ms...FZWCaQod-lUAjQ
I got this info by going on-line and Googling "MSD ballast resistor"
Larry
Larry
Larry
Larry
update
Those of you who have followed this thread, I took my multimeter with me and returned ballast resistor. Napa had another in stock, so we checked it - also read 5.5 ohms! I called echlin help line from store and guy told me they must have mis-packaged these. Ya think? He said to try a different part #, told me it was supposed to be .8 ohm unit I was after. Well, not in stock, plus computer showed new part to be 5 ohm, not .8!! So much for quality control - I guess I'll order on line and pray.
