C2 newbie: how does it work?
Hi all,
after almost 2 months of shipping I finally received my 67 corvette coupe!
It is my first mid year after several C3 and even though I own a 68 that share the same chromosomes, several things are new to me.
I know that this car will need work, but my intention is to start a slow process of restoration to enjoy the car in the meanwhile.
For those who wander the net in search of new cars, you may already know this one: it was the DARE program 67 for sale few months ago.
Said so, I'd like your expert eyes and help to figure out how to bring some of the parts back to original or at least correct condition. I will put pictures as soon as I can.
In the meanwhile, how are the headlights supposed to pop up? Just pulling the light **** or pressing the switch that says headlights? Tried both but they didn't work...
The headlights don't pop up. They roll over slowly. You hold the headlights switch (under the dash, spring loaded, pull for roll over, push for roll down) until the headlights roll completely over. If stock, takes about 5 seconds of holding. Also if stock, there's a blinking red light on the dash that flashes "lights" until both buckets are completely rolled over (if you have the headlight switch pulled on). The light doesn't flash if you don't have the headlights on. It works this way with or without the ignition switch on.
If neither bucket moves at all when you pull the switch under the dash toward you, you probably have either a dirty switch (from non use) or a bad circuit breaker (mounted on the left kick panel). You can easily determine where the issue is if electrical. Measure for 12v going into the switch, then coming out on one of the other wires (there are only three) when you push, and on the other when you pull. If you don't have the 12v on any of the wires, check the voltage on both sides of the circuit breaker, If you do have the 12v there, check for it coming out of the firewall connectors below the master cylinder. If you have a mechanical problem, you'll have to get help from someone else, I don't disassemble the motors or gears unless it's an emergency and I haven't had one of those. If they try to move and growl or grind or vibrate, you have a mechanical issue. Check the voltage first. The rollover switch is a common place to lose the voltage if they haven't been used much. If you use Google and search C2 headlight rollover switch repair" you should find several sources for taking the switch apart and cleaning the contacts. It's nearly impossible to find a good replacement switch, so be very careful disassembling and don't brake the plastic. It's a very simple switch and easy to remove (two screws), but make sure it's bad by measuring the voltage in and out. If it's there on the center wire, but not on the other two when you activate the switch, it's definitely the problem. Here's a 65 diagram, but the 67 headlight switch system is the same.
The motors can be bench tested, I would check the wiring first. Although removal isn't fun, installation is difficult with the hood on, or I should say uncomfortable in the position you have to be in.
Another quick way to see if the voltage is there and the switch working is to watch your battery gauge (ammeter) on the dash. When you push or pull the rollover switch, the gauge will deflect to the left if you have the voltage and the switch is working. Keep in mind that the voltage must pass through one of the two connectors on the firewall just below the master cylinder. Save the diagram I posted and then open it up and zoom in on the bottom where the headlamp switch is located and you can see the colors of the wires in question.
Received 6,996 Likes
2015 C2 of Year Finalist
I would first check to see if you can roll them over by hand to make sure everything is free and not seized up. and sometimes that's all needs to be done. if you open the hood the feel around the center of the noise you should feel two "star" wheels. start rotating them. its going to take a while. also buy a owners manual, and a assembly manual
I tried to charge the batt and now seems they are working, slow and uneven but working.
Will appreciate a guide on how "fine tune" them.
I already bought an assembly manual just in case.
Another question is about the interiors. The previous owner started a complete restoration and did a really good job. At the moment the only two things I'd like to work on is the different color of the needles in the instrument and the different shades of blue in my dash. I've already seen other cars with the same "issue", but are those differences of color something coming with the age? Is there something I can do to make everything of the same color?
The dash pads appare to the correct color along with the rest of the dash. The speaker grile and radio side panels are way to bright.
What's wrong with the neddle colors
That's going to be a lot of work to get to them. If you have hobby stores over there with plastic model cars the paint for them will work very well to correct that. But if you have it that fair I would send it out to be restored
The headlight motors are a cinch to rebuild (I have a good article on the procedure).
Usually the main drive gear is galled (repros are available) and the grease has congealed into yellowish-white clay.
Of course exercising care to not break the original switch is the right thing to do, but Zip and and Long Island Corvette show a replacement headlight rollover switch for $99 or so. I don't think Paragon lists it. Does the repro switch have a bad track record or substandard appearance?
Just curious.
Steve
Just curious.
Steve
Just curious.
Steve
Just curious.
Steve
Be sure to keep any original takeoff parts for future restoration since they're usually better quality than replacements and can usually be rebuilt...
