C2/C3 Driveshafts and yokes
St. Jude Donor '05, '09, '15
I have a Richmond 5 spd in the 65. I am currently using the stock driveshaft. I use a T400 yoke in the trans with 1330 u-joint. I use a conversion joint to match it up with the smaller 1310 u-joint drive shaft. Alls good. Now I am putting in a diff from a 75. It uses the 1330 u-joint. It's built and ready to go in. Will the larger yoke fit in the tunnel without issue? Instead of buying another conversion joint will a C3 driveshaft fit and use 1330 joints on both ends?
Tom
Tom
Tom
Tom
hard to say
I have solid body mounts from the 68-72 years under my C2, because I am running a ROD and 1350 to 1350, but I had to cut glass in a couple of places based on raising the rear diff with the removal of the donuts and welding the rear crossmember. I would think as long as your mounts are in good condition, and you dont have sagging floor boards etc. you would be fine.
