Oil Filter cannister filter decal alternative?
For a 66 using the PF 141 cannister oil filter
I have tried the decals but these fail quickly due to engine heat.
Has anyone made a paint stencil or mask to apply the white lettering?
There must be one Forum member with graphics experience that can produce such a stencil.
Would love to hear from anyone with a solution other other than sending it out to be silk screened.
This is not rocket science.
Possibly use satin clear coat lightly over the decal ?
I've done that on valve cover decals before and it worked...
Those decals never look good.
I really would like to use a stencil or mask to apply white paint as I feel this is the only permanent solution.
Ron
Received 7,000 Likes
2015 C2 of Year Finalist
Pay to have silked screen like original. Or buy a new repro that is silked screen
I would find an oil can restorer and pay to get the work done. There are two or three that I know.
I personally used Ken Hansen of OrinDales…..but there are others.
Larry
Received 1,859 Likes
Send it to Ken Hansen at Orindale's - he's the "guru" for absolutely correct stenciled original filter canisters. Nothing else you'll try will work out long-term.
Ken did the oil can silk screening on my 63 motor and it's very nice. He also makes sure all surfaces are flat so no leaks. I installed a decal on my 67 can and when it goes south the can will go to Ken to get fixed correctly.
