1965 fresh air vents leak
Old 05-08-2015, 08:44 AM
bpjon65
bpjon65's Avatar
Default 1965 fresh air vents leak
I never had this problem until the car was stripped and painted. I have taken off the wiper cowl vents and cleaned them and the sides that drain water with air and water. I did get a lot of debris from the drain hole under the car. I still get water coming in from the fresh air vents. I have now removed the fresh air vent cover and flapper. There is no debris inside. Will a new fresh air vent seal kit prevent water from getting in? Any help , any ideas. Thanks.
Old 05-08-2015, 10:16 AM
MikeM
MikeM's Avatar
Received 1,843 Likes on 1,398 Posts
Put dum dum around the flange and screw it back down.
Old 05-08-2015, 11:31 AM
Tampa Jerry
Tampa Jerry's Avatar
Received 1,324 Likes on 957 Posts
Default Seal kit
Buy the kit from Dr. Rebuild. It is really inexpensive. If original, your seals are almost 50 years old. It may also be a good time to check on the operation of the cables and add oil to them. Once replaced, you can check with a hose to see if the fix prevents water from getting into your interior. Good luck. Jerry
Old 05-08-2015, 03:41 PM
Frankie the Fink
Frankie the Fink's Avatar
Received 7,082 Likes on 4,736 Posts
Army
If its like my '63 the rubber seals are sandwiched between two metal plates and secured with rivets. Not much fun to change but its doable and helps seal the cockpit a lot.
Old 05-08-2015, 06:34 PM
DansYellow66
Support Corvetteforum!
DansYellow66's Avatar
Received 2,615 Likes on 1,947 Posts
I don't believe you should be getting water in through your vents even with worn out seals. GM didn't design the car to require the owner to remember to shut the vents every time they walked away from the car to prevent rain water on the floor boards. You have something else going on in there. Since you have the grill and vent out, I would run some water into the cowl vent while watching the vent opening to see where and how it's coming in. I think there is a diverter and dam around the vent opening inside the dogleg and maybe it has been damaged somewhere on the top side. Has the front clip been replaced on your car? With the vent out you can reach in there and feel if the diverter flange is intact all around the perimeter.
dbw (05-29-2020)
Old 05-08-2015, 06:55 PM
Frankie the Fink
Army
A VERY good point
1960 (03-03-2022)
Old 05-09-2015, 08:55 AM
bpjon65
bpjon65's Avatar
Thanks for the input. Front clip has been replaced. I'll have to feel around the diverter. I am going to install the new seal kit.
1960 (03-03-2022)
Old 05-09-2015, 09:00 AM
bpjon65
bpjon65's Avatar
Default 1965 fresh air vent leaks
Thanks for the input. I have the new seal kit to install. The rear clip was replaced, but I'll still feel around the diverter.
Old 05-09-2015, 11:06 AM
c2 husker
c2 husker's Avatar
Check your windshield seal too ! Mine was leaking and running down the vent area and onto the carpet !
Old 05-09-2015, 01:43 PM
ghostrider20
ghostrider20's Avatar
I thought there was a drain hole somewhere at the bottom of the plenum? If that us plugged, water will flood he plenum area and spill out of the vent. In any event, you don't want water sitting in the plenum.
Mark
Old 05-09-2015, 03:34 PM
C2Racer
C2Racer's Avatar
This is exactly correct. I agree, if the drain is working water should pour on your feet when you pour it in the cowl vent. Otherwise I also agree check the windshield gasket.
Steve
Old 02-20-2017, 11:44 AM
LEEROY JENKINS
8th Gear
LEEROY JENKINS's Avatar
How are these vents designed to open and close? Mine looks just like the one pictured in post #4, no control attached to operate it. Or is the control cable not in view? It opens and closes easily with my hand.
Old 02-20-2017, 11:52 AM
LEEROY JENKINS
8th Gear
Never mind, found this. Looks like I am missing the control completely!
https://www.corvetteforum.com/forums...e-routing.html
To 1965 fresh air vents leak
Quick Reply: 1965 fresh air vents leak
