1966 Heater Blower Wiring Connection
Guys I have a question on how to connect the heater blower motor to my new wiring harness on my '66 coupe. It seems that the two black wires are grounded to the motor frame, but do I need a resistor between the power (orange) line and the motor? I seem to be missing a connection piece to the motor. Any suggestions?
Thanks.
Dutch647
Thanks.
Dutch647
The only connection I see is for the ground connection? I must be missing something?
Dutch647
Received 1,857 Likes
The 12V connection is a rubber-insulated male spade at about 5:00 on the motor flange - it takes the rubber-covered female terminal on the black wire from the radio capacitor (or on the orange wire if you're not using the capacitor). The blower ground connection is a bare spade terminal screwed to the motor flange right next to the 12V connection.
1966 Blower Motor Wiring
Dutch647
Here's another showing the wiring. You have the correct 12v terminal there on the motor, no need to change that. You're only missing the brass 90* male terminal that is held in by the screw shown at the rectangular connector.
Rich
Rich
Rich
Rich
Dutch647
Yes, as John said, if no capacitor in series, just plug the round Orange terminal to the 12v motor terminal. This is what they did if no Radio.
Yes you can connect the 2 Blk/Wht grounds via a jumper of some sort to the ground screw and it'll be functional. Since you have a new harness you probably don't want to cut the plastic terminal connector off.
Rich
Rich
Rich
Rich
Have a great week!
Dutch647
