Speedo gear question
I recently changed my 4.11 gears to 3.36 on my 63. I bought the correct speedo gear for the 3.36 with the BW T-10 factory trans. Now the speedo will not read correctly.It goes to 20 MPH and after 4th gear stays about 40 MPH. If I tach at about 3000 RPM (which feels like 75 MPH) it might get about 50MPH. The speedo worked fine before but was off about 10 MPH according to my GPS after the change out. The cable connection is finger tight. What did I do wrong ? I hate to change out the gear again cause it is a PITA and my fingers just now healed up after the first gear change.Any ideas or helpful hints would be greatly appreciated.
Jack
What color gear did you remove, and replace it with
For a 3.36 it should be small 8 tooth circle gear and use a "20 tooth BLUE gear"
For the 4.11 should be small 8 tooth circle gear and use a "24 tooth YELLOW Large gear"...
Both were based on 27" diameter tire...
The above calcs were from this site...
ww.stl-vettes.com/65Vette/GearCalc.htm
I removed a silver from my 3:70 which was perfect. Do I put in a blue now that I will have a 3:36?
Jack
I have the wide drive gear.
Jack
Received 1,856 Likes
Changing to a 3.36 rear puts you in the other "family" of both DRIVE and DRIVEN gears. You need to pull the transmission, remove the tailhousing, remove the existing pressed-on DRIVE gear, and install a large-diameter (1.85") replacement, which will mesh with the "small" DRIVEN gear family that covers 3.08 to 3.70 rears - you need the 20-tooth blue (#3987920) gear.
The alternative to pulling the transmission is to have a speedometer shop make up a ratio adapter gearbox that will work with your existing "small" DRIVE gear.
Received 3,766 Likes
2023 C1 of the Year Finalist - Modified
2015 C1 of the Year Finalist
Your car was "born" with a small-diameter (1.77") DRIVE gear pressed on the mainshaft, which only meshes with the family of "large" (0.87" dia.) DRIVEN gears that work with 3.70, 4.11, and 4.56; yours had the yellow 24-tooth gear for a 4.11.
This is the exact correct answer!!!!!!!!!!!!!!
I just replaced the speedo driven gear in my 3.36 because I was going about 10 mph under actual. I replaced it with the 20 tooth blue. Before I did, I read up on this forum about people dropping the old driven gear in the tail while they attempted to extract it, so I was ready for it. Guess what? Mine dropped in. I fished for an hour with my trusty long flexible claw and never did find it. Finally gave up, buttoned everything back up, took it for a ride, no sounds or grinding and my speed is dead on according to my gps.
Manchester Muncies in Manchester, Iowa sells the adapter.
I bought my ratio adapter from these guys, they have everything you need in gears also. An adapter is much easier than trying to change the drive gear.
Performance Transmissions and Parts
www.TransmissionCenter.net
Parts Toll Free 1-888-2012066
Transmissions Toll Free 1-888-2012066
Speedometer Gears 1-888-8771008, 6:30 to 5:00 CST, M to F
PATC Speedometer World
There is a speedo gear calculator at this link:
http://goo.gl/hK2jbU
You can now get 7 and 8 tooth drive gears for the Muncie in the 1.84 diameter. They are all over Ebay.
The document below has all the info you'll ever need about DRIVE and DRIVEN gears, what works with what, how to identify them, etc.
Yes, it did, but not during midyear production - the 22-tooth #3987922 silver "small" family DRIVEN gear for 3.70 usage came along a few years later.
Pictures are worth a thousand words
Here are some pictures of the small and large drive gears and driven gears. My tranny had a dented drive gear that ate plastic gears for 40 years. When I did my tranny over 5 years ago, we found the dent in the gear as you can see. My car came with a 3:36 and I put in a 3:70 44 years ago, and the speedo never worked.
I took out the narrow gear that was damaged and put in a wide gear with the 3:70 and that was a silver gear. Was dead on speed with GPS
Now that I have a 3:36 , I hope the blue gear will work for me.
Here are the pictures
See the dent in the gear
See that damage to driven gear
Narrow Gear and Wide Gear
Damaged Gear, hit with spike tool when installed years ago
The 18-tooth brown gear ("small" family) is for a 3.08 axle - it will NOT work with a 4.11 axle. You need to verify a) What axle ratio you really have, and b) What DRIVE and DRIVEN gears you need for your application.
