C3 fiberglass spring work on a 67?
I found one that is supposedly in new, perfect condition. It just says it is for a C3. Would it work on my 67 coupe or would I need to know if it is for '77 or earlier? Also, since it seems that they went to composite on 80 or 81 and up, does that matter? Basically, 63-82 use the same ones other than spring rate? Thanks for any insights.
Like this:
Like this:
Received 1,857 Likes
Check the WIDTH of the spring where it bolts up to the rear cover - I think you'll find that the midyears are 2-1/4", and the later C3's (including the ones with the composite spring) are 2-1/2" wide, and require a unique rear cover and spring retainer plate with a different spring bolt pattern (and smaller-diameter bolts).
