1967 speedo hookup
1967 speedo hookup
Which side of trans does the speedo go on a 1967 corvette Muncie with a BIG BLOCK. I know it is the passenger side on a small block, just wondering if all the c-2 are on the same side?
Received 6,943 Likes
2015 C2 of Year Finalist
still on my be passenger side
Received 1,857 Likes
Small-block or big-block makes no difference - they all used the same transmission with the 584 tailhousing, which had the speedo drive on the passenger side from '65-up.
Not sure what the question is... Are you talking about where the speedo cable goes in to the transmission? If so, mine is on the drivers side....
spedo
Thanks, A friend of mine just bought a Muncie that was marked 67 corvette. and suposed to be rebuilt, when I seen it I told him it wasen"t a 67 corvette because I have one in my shop that is out of a numbers matching car. When he called the guy and asked him he got##3$ . So needles to say I also told him we will have to pull the cover off to see what is inside before I put it in his car. Just wanted to check to see if BIG BLOOK was different.
