Horn issues on a 63 Roadster
Went to a local show today with my 63 corvette roadster. To my
embarrassment, my horn started blaring and would not stop. Every
time I touched the horn button it would go off, very touchy. Is it just
the three screws on the inside that need adjustment? If they touch metal, the horn goes off.
Reds
Reds
Received 1,857 Likes
Reds
Reds
If the contact assembly isn't corroded, they can be rebuilt with new nylon insulator buttons, or just replaced.
That washer isn't "insulating" anything - probably just a spacer so the horn button is parallel to the surface of the wheel when snapped in place on the "prongs" on the black spring steel portion of the contact assembly.
Horn Button
bI will mess with it tomorrow. I hope to find the issue
Seriously, it is indeed a touchy arrangement. They make nice repro versions of the part in the pictures above but it might just need some small tweaks.
FYI - if it should happen again you can always reach down forward of the hood and just pull the connectors off both horns temporarily to get you home -- quietly
