Is there an order/sequence when tightening down a hardtop?
Recently purchased a 1962 and removed the hard top, looking to put it back on. Is there a preferred order for bolting it down?
I'm not sure if there is a correct way, but the method I use works for me.
Mike
Received 1,267 Likes
2021 C1 of the Year Winner - Unmodified
2020 C1 of the Year Finalist - Unmodified
2016 C1 of the Year Finalist
Just mounted mine on the '62 on Friday. One guy on each side, carefully lower it on, rear first. Get the deck lid bolts in place finger-tight, then the side bolts. Finesse the windshield header pins into their slots and secure both front latches. Now tighten the four bolts with your gen-you-wine GM-issue Corvette Hardtop Bolt Wrench (you DO have one of these, don't you?) and you're good to go. Took me a total of 12 minutes. Enjoy!
I find the best way to do it is to first lay a blanket on the car, and arrange it so it does not interfere with the rear bolts pointing down from the hardtop. Even with a helper it is easy to scratch your paint, and the blanket can be slid out after the top is in place. Slightly snug up the rear nut-bolts first and then connect the front latches last. Hope this helps...Best...
Most folks never look but the windshield header receiver bracket for the top pins (hard or soft top) are a hole on the DS and a SLOT on the PS. Look down from the top and you'll see this - so, always latch the DS first and the PS pin will index automatically to a proper position. Finally, you only need to tighten those rear bolts enough for the weather strip to seal...there is no need to crank down on them to the point you crush the rubber to death.
The correct order is to put the top on the car first, then bolt it down. If you put the bolts in first, it's harder to get on the car.
(Sorry, just my weird sense of humor)
On my '67 - after getting it carefully and properly positioned with 2 people - I find it best to leave everything else loose until I can get the side bolts inserted and started. It's a b*tch to get them to line up if other things are tightened first.
Then I do the front latches and last the rear bolts. I agree with the previous comment about tightening them just enough to close the gap between the weather stripping and the rear deck.
Lastly you might want to consider getting one of the clear plastic protectors for the rear deck, especially if this is your first install after a new paint job!
