Will an LSA fit in a C1 without cutting the hood??
Hi All,
I have scoured CF looking for info to see whether the LSA can physically fit in the engine bay of a 58-62 without needing to cut up the hood- but can't find anything on the subject. I have serious doubts it would, but figure it is worth the question!
Is anyone with an LS3 in either a modified stock/AME/Sriii/Newman chassis able to assist and measure from highest point of their engine and the underside of the hood clearance for me?
I have read somewhere the Sriii engine mounts are the lowest of all aftermarket chassis but not sure if it still would be enough.
Alternatively, if a forum member has access to an "as-delivered" LS3 and a LSA for comparison measurement that would be invaluable!
Thanks in advance!
Thanks in advance!
2018 C2 of Year Finalist
St. Jude Donor '12-'13-'14-'15, '19
I can't say for sure, but my guess is it would. The old blue flame six was pretty tall.
I like where you're headed with this. Be sure to do a build thread.
I have seen at least 3 in the Houston area, seems someone I routinely see has one but I can not remember WHO. I will ask around and try to get some pics.
I recently helped one of my buddies put an LS3 (roll-over from 2011 Camaro) in a 63. Height clearance is no problem because no carb...LS3 has low profile with intake tunnel, not carb sitting on top of intake manifold.
Joe
Joe
The LSA is a tempting product, great value for HP.
I have found a drawing online that indicates the LSA is 30.15" from sump to highest point, and the LS1 is 27.5".
Different sumps might change the numbers a bit, would be more accurate to measure from crank centreline to top I suspect.
But based on this info as as a start, CF restomod owners out there- What's the likelihood of ~4-5" of clearance under the hood of your C1/LS Combo?
Hi All,
Thanks in advance!
Thanks in advance!
Charles
Received 4,583 Likes
C1 of Year Finalist (appearance mods) 2019
Here's one in my area........no problem.
Thanks Kerrmudgeon, looks like a nice ride in the making!
How close will the front portion of the intake runner and throttle body be to the underside of the installed hood?
I'm ok with the need for changing the steering and side mounts, was thinking R&P and aftermarket chassis anyway. Troy Trepanier built a 58 with an Art Morrison chassis and a LS3/Edelbrock E-Force 416 Crate engine combo, but this had a modified supercharger cowl to fit and the Eaton blower looks like a lower profile than the LSA version.
The Edelbrock option is crazy expensive though, whereas the LSA is more reasonably priced, but if it don't fit- it's no good to me....
