which alternator for 64 with A/C Vintage
I need a new alternator for my 64 327 coupe with vintage air. What amp rating should I go for? Is 55 amps enough?
55 amps was used on non TI with C60 engines, and should be enough.
I think original air cars with TI came with 60 amp alternators. In any event, when John Pirkle rebuilt mine I asked him to upgrade the amperage (while not changing the stamped-in original rating of 37). He told me that it is now 60 amps.
I will install a breakerless SE, does that work with the airco at 55 amps?
C60 = air conditioning
Smart move. Breakerless SE is the best thing you can do if you are not upgrading your coil.
If you have a choice between 55 and 60 amps, I'd go with 60. 55 amps should do fine however.
I will install some radio improvement gear (modest though), and satnav integration. So I may need some extra amps on top of the 55. Any suggestion where to buy a plug&play 'perfect fit' 60-70 amps or more?
You can get 70 amps with one of these:
http://www.jegs.com/p/Powermaster/Po...34946/10002/-1
If you need more than that you will have to modify your charging system and use an internally regulated alternator.
The highest amperage you can get in a 10dn alternator that was used until 1969, is 61 amps.
I had my stock '63 55 amp alternator upgraded internally to 70 amps max output when I added Vintage Air A/C. It works fine. NOBODY was running 135 amp alternators with A/C in '64
St. Jude Donor '10
I have an original 55amp on my 65 with Vintage air and it's marginal at best. I'm thinking about taking it back to the rebuilder for a few more amps. I'd say 65 amps would be the minimum for acceptable service.
Well, it does, sometimes, usually those days you really want to go driving in a classic car (forecast for tomorrow is 86°F!, time for my Cobra with 'natural' A/C)
