Glove Box lock removal
I restoring my 1957 Corvette, and I ran into a problem with removing the lock from the glove box. I have new locks for the car, and I need to do some bodywork on the glove box. Can someone tell me how to remove the lock from the glovebox when I do not have the key.
Thanks,
Pat
Thanks,
Pat
Thanks,
Pat
Thanks,
Pat
If you do not have the key, there is a way to open the glovebox...but it may take a little patience. The moveable lock mechanism is attached to the door itself, and it just hooks under the small,thin metal catch. I have used a thin piece of plastic (for example, cut a piece 1" x 6" out of the side of an old prestone anti freeze container, but anything similar will do) and slide the one inch side down between the door and glovebox surround just where the lock is, and the door will pop right open. Do not use a credit card, it is too stiff. Hope this helps, and avoids unnecessary damage...
Then take it to an 'old timer' locksmith, once he gets it removed he can cut an "original key" for your lock...
