Side pipes install-bird cage straps removal?
St. Jude Donor '07
Side pipes install question - Did the factory equipped side pipe cars have the rocker panel trim braces welded to the bird cage. I have seen them bent out of the way or the vertical section cut off for clearance when side pipes were added. I am trying to wire brush up inside the bird cage sill. I could get better access if I cut off the entire rocker brackets. (body is off frame). So does a factory side pipe car have any horizontal braces across the bottom of the bird cage sill?
St. Jude Donor '07
Sorry. I did not ask the question clearly. Does a factory side pipe car have any horizontal braces across the bottom of the bird cage? If I remove the entire bracket will it look correct?
Received 6,929 Likes
2015 C2 of Year Finalist
Yes it will be correct.
I fail to see any upside in helping to create faked cars by posting an image like above in reference to the question asked.
It certainly will be now.
Mike Coletta
No. But thanks.
65hihp
65hihp
St. Jude Donor '07
I will not be using the brackets. Some are rusted out and also in my way for cleaning and painting. I do not intend to create a fake. I just do not like to hack up a good Corvette. I do appreciate the factory stock appearance with some slight mods. Thanks for the feedback.
