New Mufflers for my Corvette
Steve
I went on CC's website to compare Magnaflows and N11s. The description for Magnaflows says, "The Aluminized, all welded straight-through design" and "There are no chambers, no baffles and no louvers to restrict exhaust flow. You get wide open performance from Magnaflow." If there is nothing inside these mufflers aren't they going to be pretty loud? The ones in the videos didn't sound like they were straight through. Anyone have an opinion?
I don't remember looking through them but they are not loud.
Steve
Steve
Google the Magnaflow web site. It explains all about their inner construction. I have a set (actually 2, my car and truck) and no, they're not too loud. Nice deep tone at idle, throaty on acceleration but plenty quiet enough for cruising.
Gary
Gary
If you're curious about our muffler construction still, the stainless straight-through core is perforated and wrapped with stainless mesh, then the remaining muffler body is filled with sound absorption material. It's surprisingly effective at reducing sound without creating additional backpressure.
Thanks for the business!
Good question. We don't have a cat-back or direct-fit exhaust system for the C2 and I don't have the C2 exhaust dimensions anywhere that I know of, but if you can get height, width, and length of the muffler with a pipe diameter, I'd bet we can find something that will fit.
Here are the mufflers alone at Corvette Central.
http://www.parts123.com/corvettecent...50b&ukey=37334
Steve
Steve
I got the off-road from Allans, I started it up, reved it, shut it off and ordered some Magnaflows, If you got a Harley with straight pipes dont mess with the off road and N11 stuff. I just went through the extract same thing you are going through.
I have a 79 C10 with a old and wore out 305 with 8.5:1 compression, Its got Magnaflows, I get compliments of how it sounds.
mufflers
I have a brand new set of Allens I purchased many years ago still in the original boxes. Would sell very reasonable. If you have any interest let me know, just collecting dust in my garage!!
Thanks,
Frank
Thanks,
Frank
#33
My new Magnaflows will be delivered tomorrow. Am I going to have to take out the spare and the carrier to get these mufflers changed out? Anything else I should watch out for? I am going to have to wait until after the 4th of July weekend, but I am anxious to get them on.
#34
You should not have to do that but....the old mufflers maybe pretty stuck to the exhaust pipe and bent into an oval from the clamp. So when beating them apart be careful you don't hit the spare tire tub and split it. Seen that happen. Spray it down with WD40 or better heat it up with a torch to get them apart. Be careful with that torch too!
Steve
Steve
#35
Steve
Steve
#36
Our mufflers are usually pretty direct fits, but if you have any trouble give our Tech Support line a ring: 1-800-8248664. I believe they're out tomorrow and Sunday, but they'll be there at 7 a.m. PT on Monday.
#37
Thanks for the recommendation. Was going to poke in here, but I think the general description of our mufflers' sound from our website's FAQs really sums up what you'll get nicely:
Hope that helps the OP!
Question is, has anybody ever put that kit to the test? It seems impossible to to take the limited number of pipes included and make it work for the number of awkward bends under the C2.
#40
I got the Magnaflows installed Saturday about 4 PM, just in time for the everyday rain storm. (Florida) So I had to wait until about 9 to try them out on the road. You cannot make a judgment about these mufflers listening to them in the garage or on YouTube. You have to get them out on the road where you can get down on it and go through the gears. Even from the driver's seat in a convertible they sounded great. I like 'em. The sound even mixes in well with my stereo. Until you punch it under load they have a mellow rumble. I would recommend Magnaflows for a 327/300 engine. The CC version bolted right in. The mufflers themselves were about 3 inches shorter than the stock ones so I was worried about them fitting in right. As it turned out the inlet pipe was longer on the Magnaflows and they fit perfectly. The only problem I had was that I spent about an hour trying to get the first old one out without taking the hanger out of the car first.
I appreciate all the help I got from the forum on this decision.
