Ididit Steering Column length?
Anyone have an Ididit steering column for a 1958-1962 ya could measure? Need the measurement from the end of the shaft to the edge of the bell.
I have one part#1010720010 from Ididit and it sure seems its about 1" too short….
I am using an Art Morrison frame with power rack and when I install it the rod hits solid against the headers and is off to the side - not centered coming thru the firewall….
I am emailing Ididit to see if they sent the wrong column or maybe mine is too short…
Thanks in advance
Thanks in advance
Thanks in advance
Thanks in advance
Would it be better if this column was longer than the 36" they advertise
POL has them on sale with 10% Nov 27 ONLY !!!
I ran into a similar problem when I did my ’59. I used an Ididit steering column with a C4 rack and pinion front end. The steering shaft had to fit between two of the exhaust header primary tubes, so the length of the column was critical. Initially I had a stock Ididit column. I believe it was the “stock” length that Ididit sells for C1’s - not sure what the exact length was though. This column was not quite long enough so I purchased a column extension adaptor that Ididit sells, this extends the column about 2”. The extension worked, but I didn’t like the appearance so I ended up cutting the Ididit column up under the dash so it would not show and extending it the exact amount that I needed. I purchased my column through Billy Dawson and I think he told me after I already fixed mine, that Ididit will make a column any length you want. I can measure my column, but I doubt it would be the length that you need. If you are interested (and if I can find it) I will send you the adapter.
Below is a picture of my finished column and the column adaptor.
Charles
Charles
58neverending (12-05-2020)
Ididit column
I ordered a custom IDIDIT column (longer) from Billy at Corvette Corrections in Texas - worked great...
I talked to Flaming River guy last weekend at the G Guys in Snottsdale and he said it was just a "tube" and they could make it any length I wanted, just call Brett Domin at F River
I too decided that was the best option back when I researched it . Mine fits perfect..and the dimensions in relation to the headers are critical.
